Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 10-30-2008, 12:56 PM
Josh Smith's Avatar
Josh Smith Josh Smith is offline
Send a message via Yahoo to Josh Smith
1993 Olds Bravada Will Not Downshift When It's Cold Out
Hello,
I'm not a transmission man my any stretch of the imagination.
Last year when it was cold out (single digits) the transmission would, at times, fail to downshift when I stopped. This was rare though.
Recently, as in the past couple days, it's been doing this more frequently, maybe 50% of the time. The temp has been around 60*. The only fix I've found is to manually downshift. This usually works, probably 90% of the time.
It's been serviced regularly and has no burnt smell or off color to the tranny fluid.
As far as I can tell, this transmission is not computer controlled. There is no pump noise and it upshifts fine.
A typical session will go like this: It's cold out. I start the truck and it drives fine. After about a mile, it will stop downshifting. I turn it off for a few minutes, and it will start downshifting again (sometimes).
What do I need to look at first? Ideas?
Thanks,
Josh
1993 Olds Bravada, tow package, power everything and leather seats. Currently in restoration. - RIP. Your engine and drive train were excellent, but in the end, too much rust.
2000 Blazer, loaded, looks showroom new, bought April 4th, 2009
Old 10-30-2008, 03:17 PM
Josh Smith's Avatar
Re: 1993 Olds Bravada Will Not Downshift When It's Cold Out
Update: It seems to be first gear that's missing. I seem to have second, third and OD. This makes no sense to me as I *thought* that, on a 4L60E, one solenoid ran first and third. It would seem third shouldn't work either...
Josh <><
Old 11-01-2008, 07:53 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Hi Josh,
Shifting manually is supposed to overide the solenoids.
I believe the 4L60E would have the 20 wire pigtail connector on the passenger side of the trans.
Old 11-16-2008, 03:22 AM
Josh Smith's Avatar
Thanks Chris. Manually shifting isn't getting it either.
More info: I have first gear until the trans warms up. That's when I lose it. I have OD most of the time, but lose that sometimes too.
I'll check for the pigtails.
Any idea what may be happening?
Thanks again,
Josh <><
Old 11-18-2008, 09:22 AM
AF - Advisor
Just did some looking in the '97 manual since it has a 4L60E trans and there was the usual pump & pressure solenoid info which applies since the trouble occurs after the fluid warms and thins out a bit.
My '97 had a no pulling in 1st gear issue that worked out ok after wiggling the 20 pin connector and checking the other wires routed over the trans....basically I was checking the wire insulation in case it was nicked on casting flash of the trans case. Finding none, I reset the DTC with my scan tool and everything was ok so I gotta think there was an issue with the connector.
I'm not gonna ask about a check engine light since even the dealer techs couldn't get a handle on Olds OBD1/OBD2 combined wreck.
