Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 10-30-2008, 11:57 AM
kyleag89 kyleag89 is offline
Oil pressure switch
I have a 94 firebird 3.4L with 100,xxx miles. Just recently my cat broke and created an exhaust leak. Since that happened my oil pressure would shoot over 80 psi when I took my foot off the gas. When idling the car is fine and holds about 20psi then when Im at 2000rpm its at 60psi but when I take my foot off the gas it shoots to over 80 for between 2-30 seconds. I thought this might be because of some kind of back pressure from the hole in the exhaust so I replaced my cat and still has the same problem. I dont think I have a faulty guage because the car smells like burning oil and has oil all over the bottom of the engine which wasn't there before.
So do you think I might just have a bad oil pressure switch?
Old 10-30-2008, 03:26 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Oil pressure switch
first find where you're losing the oil at. could be coming out of where the pressure switch screws in.
Old 10-30-2008, 03:55 PM
The problem isn't where the oil is coming from.... The oil didn't start to leak until about a week after the high pressure situation. I believe its only leaking because the engine is running over 80 psi with nowhere for the oil to go.
Old 10-30-2008, 04:23 PM
Genopsyde's Avatar
The President
drop the pan and change the pump then.
Old 10-30-2008, 06:22 PM
Would loosing oil cause my pressure to shoot through the roof?
Old 10-30-2008, 10:26 PM
Does anyone know where the oil pressure switch is located on the 4th gen Fbodies? Ive searched but I cant find anything. Thanks
Old 10-30-2008, 11:32 PM
poormillionaire2 poormillionaire2 is offline
Its right above the oil filter. You'll have to jack the car up on the driver's side. You'll also need a special deep socket to remove it too. Later models have it located behind the intake manifold on the driver's side.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
