Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 10-28-2008, 10:39 PM
michaelodonnell123 michaelodonnell123 is offline
Bad gas mileage
Hello everybody,
I have a 2008 Cobalt 2 door coupe, I bought the car about six months ago, lately my gas mileage has been terrible, I am getting 20 miles per gallon the most whether its highway or local driving. My driving habits are very easy, no A/C on and no heavy load. My tires are filled up a few pounds over the recommended tire pressure and I keep up with my oil changes. Any suggestions would be helpful before I go to the dealer.
Thanks!
Old 10-29-2008, 10:31 AM
Schrade Schrade is offline
Re: Bad gas mileage
No check engine light?
Sounds like something has tripped up OPEN LOOP mode, which is cold start operation / MAX fuel delivery to motor.
Old 10-30-2008, 08:59 AM
MZR_47's Avatar
MZR_47 MZR_47 is offline
Send a message via MSN to MZR_47
Re: Bad gas mileage
Yeah, my guess is open loop on an injector. Same thing happened to my friend's Redline. Does it misfire at all? If so, I will bet that this is the case.
Check your spark plug gaps too, set the to .32 or somewhere around there.
See if you can get a hold of a set of injectors and swap them out, see if that works. You can probably have the dealership do this.
MOAR BOOST
Silencer Delete | SPT Catback | Megan Racing DP | TEIN Flex Coilovers | Front and Rear Sway Bars | DBA Rotors | TurboXS UTEC | 18 psi
Old 12-07-2008, 04:33 PM
corvairbob corvairbob is offline
Re: Bad gas mileage
a bad front 02 sensor with cause it and not give a code.
