Go Back   Automotive Forums Car Chat > GMC > Syclone | Typhoon
Old 10-28-2008, 10:29 PM
THE_RKD THE_RKD is offline
Unhappy 92 Typhoon Cranks, But Wont Start!
I need some technical expertise! My Typhoon "cranks", but will not start!
I have verified 'spark', replaced ECM, MAP Sensor, Throttle Position Sensor, Ignition Control Module, Fuel Pump, everything that is 'obvious'!
Is there a special, hidden, Relay, or Fusible Link, or something else that I'm missing?
THE RKD
Old 10-29-2008, 02:41 PM
maxwedge maxwedge is offline
A990 racer
Re: 92 Typhoon Cranks, But Wont Start!
Welcome to AF. Will it start spraying starting fluid inot the intake?
Old 10-30-2008, 05:56 AM
No; not even Starter Fluid has helped this beast!
THE RKD
Old 12-25-2008, 09:53 AM
rhandwor rhandwor is offline
If you have spark and fuel I would check for a plugged intake. You also need air to start.
You could also have jumped time. How old is the timing chain. Mark your timing at TDC pull the rotor turn over by hand about 60 degrees past TDC
turn back to TDC. Mark the rotor and distributor turn the engine over if you go over 20 degrees I would suspect a stretched chain. Somebody has to tell you when to stop you want to stop as soon as the rotor starts to move.
