Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-28-2008, 09:12 AM
BigDawg2 BigDawg2 is offline
Question 95 Camry fuel filter line
I went to change the fuel filter and I had a heck of a time getting the lower line removed. In the process I messed up the flare and compression fitting. So I thought I would cut it off buy a new fitting re-flare the line and be good to go. I can not find this fitting. Any ideas would be greatly appreciated.
Old 10-29-2008, 07:48 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 95 Camry fuel filter line
I believe you have to buy a new line from Toyota.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-30-2008, 10:14 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
You might check the junkyards for a used line as well. Just try not to mess this one up too...have one of the yard guys pull it for you.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-31-2008, 04:07 PM
lenjack lenjack is offline
That lower fitting is a well known bitch.
Old 11-03-2008, 11:53 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
For next time, a "crow foot" wrench and penetrating oil make it simple.
The crow foot wrench looks like the end of a flare nut wrench but is very short and has a square cut out for use with an extension on a ratchet handle. The thicker cross section elminates flexing.
I use Kroil penetrating oil.
Makes it very easy to loosen that fitting.
