Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 10-28-2008, 08:28 AM
dguy dguy is offline
2002 escape revs at startup
Hi. Daughter has a 2002 Escape. It seems to rev very high on cold startups. You know--the kind of rev where you here metal on metal before the oil gets pumped through. Is it hard to set the rpms on these?? Or what could the problem be? Thanks Dguy
Old 10-29-2008, 04:40 PM
cam 540 cam 540 is offline
Re: 2002 escape revs at startup
I would guess its a coil gone bad.
Old 10-30-2008, 01:29 AM
Davescort97 Davescort97 is offline
Escort guy
It is said that the cold startup at a higher rpm is to circulate the oil faster hence less wear on the engine. I don't necessarily agree with that. If it sounds bad when you start it, try a lighter SAE grade of oil ie. 5-30. That grade will build up pressure sooner and circulate the oil faster than 10-30 or 10-40. There is no way to set the idle speed. It is controlled by the power control module.
Old 11-01-2008, 06:53 PM
Thanks for the help guys. I'll check the coil and maybe try synthetic oil
