Old 10-27-2008, 11:18 PM
rc11982 rc11982 is offline
87 TBI question
On the Injectors onl;y one sprays when I start the truck and it sounds like it is going to stall. Should both spray? I normally work on small cars but thought I could fix the problem.
Thanks
Old 10-28-2008, 08:36 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 87 TBI question
Thanks
You should have a even spray from both.
Check fuel pressure and wiring to injectors.
Also the injector to.
MT
Old 10-28-2008, 09:28 AM
Schrade Schrade is offline
Re: 87 TBI question
Yup - ohm test the injectors...
Old 10-28-2008, 02:44 PM
Re: 87 TBI question
What should the reading be???
Old 10-28-2008, 04:37 PM
Re: 87 TBI question
Not sure for TBI. Other GM v8's have between 12 - 16 ohms as spec, for late '80's - '90's. Probably the same for all. If you get the same figure for both, they probably are still in spec...
