Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-27-2008, 08:03 PM
gatoratoy227 gatoratoy227 is offline
a few odd problems i'm at a loss for ideas on these
1st one:
my trans shifts late shift not all the time but for a few days to a week all the are late
shift points:
1st to 2nd: should be at 15 mph, mine 25-35mph 2nd to 3rd should be 25-30 mph, mine 45 to 55 mph 3rd to OD should be 45 mph, mine 55 to 65 mph
2nd problem:
rear axle geometry is off its toed in 10-15 degrees on both sides and the camber is about 10 degrees inward (positive camber) i thought at first the car had I.R.S. but upon inspection its a solid rear axle there are no suspicous welds or frame creases signafying it was it damaged by some type of an impact and the axle is perfectly aligned.
3rd. preoblem:
some times when going into a left turn because of the light suspension and the excessive body roll as a result of, there is a nice kind of "crunch" that stems from the front left suspension it only does this when turning left though never right, i know there is a bind some where when its makes said sound because, it resonates thought the car as in i can feel it bind some where and its profound you can feel it like some one just hit you in the head with a bag of nickles
NO! ,we can't stop here, this is bat country. Raoul Duke
Old 10-28-2008, 10:48 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: a few odd problems i'm at a loss for ideas on these
Jack up the radiator cap and slide a new car under it and you should be ok.
Old 10-28-2008, 11:40 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
ROFL. When I was 17 and had just gotten my first car ('75 Vega), my landlord would tell me that every day!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-28-2008, 11:41 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Don't forget the jack stands........
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-28-2008, 05:24 PM
mega420 mega420 is offline
Send a message via AIM to mega420
only thing i can say is a whole new damn suspention including addind front and rear swaybars or just junk it cause this is gonna be expensive.
