Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-27-2008, 07:00 PM
lilbone44 lilbone44 is offline
valves
i just got all my intakes and exhaust valve take out and replaced. now im having troble get the spring, retainer, and keepers back in. i used the lisle 36200 but it don't work. Any other tool i can use?
Old 10-27-2008, 08:23 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Thumbs up Re: valves
Welcome to AF.
When I do head work, I goto ACE Hardware and buy some copper tubing that's T shaped. Make some little trims here and there and use a larger C-Clamp to push it down. Then used tweezers to put the keepers back on. First couple take awhile to do, but I did 12 valves in about 7 minutes last time I did that.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-27-2008, 09:26 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: valves
I used the same thing as Dave and it worked fine. Took me a little while with each valve but I got in done.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-06-2008, 07:37 PM
Re: valves
Thanks that works great. now do anybody know where the flasher is and what i looks like. thanks
Old 11-06-2008, 07:51 PM
Holset powered 420a
Re: valves
What flasher? For the blinkers?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-06-2008, 08:03 PM
Re: valves
yeah for the blinkers. my right side blinker stays on all the time now.
Old 11-23-2008, 08:58 PM
Holset powered 420a
Re: valves
Whats the point of that pic?? No one in this thread has even mentioned cracked valves....
lilbone - I missed your other post. The flasher unit is behind the stereo on 2gens. Its a little black box.
98 Eclipse GS Turbo
2001 BMW 325i - DD
