Old 10-27-2008, 06:35 PM
himie298 himie298 is offline
Question tracker code P0463
I just replaced the gas tank in my 98 Geo tracker. and cleaned the EGR valve. I had a rusted holein the gas tank and a EGR code. Now when I started it up I am getting a code P0463 fuel sensor circuit high input. I also put in five gallons of gas and the gage read empty. I had problems with an air leak on the gage in the tank. Is it the gage that is giving the code or something else?
Thanks
Jim
Old 10-29-2008, 07:50 PM
daytonagord daytonagord is offline
Re: tracker code P0463
this means that you have a wiring problem at the tank sender, or the sender itself has failed
Old 11-10-2008, 06:28 PM
Cool Re: tracker code P0463
found the problem, broken wire on top of the fuel gage. repaired it and gas gage works and no code thanks
