Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 10-27-2008, 05:23 PM
cssteve2 cssteve2 is offline
Scooter problem (trouble giving too much throttle)
So when I'm driving 50 cc my scooter, basically it starts fine and runs fine to a certain point - but if i give it too much throttle the engine bogs down or stalls out or something and i have to let off the gas, and then give it more gas or it dies. It just started doing this, and instead of being able to go the usually ~30 mph, it only gets about 15-20 mph before giving more gas causes it stall out.
It's a pretty new scooter, I bought it in august. It's a motobravo 4 stroke 50 cc scooter.
Anyone have any idea what the problem could be??
Old 10-29-2008, 11:36 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Scooter problem (trouble giving too much throttle)
I hope Blayne doesn't see this thread, he HATES scooters!
It sounds like the automatic clutch is not working properly
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-29-2008, 01:59 PM
aussieidiot's Avatar
aussieidiot aussieidiot is offline
Gone crazy! Back soon
I thought some one was joking.
I mean who ever thought of a scooter with "too much throttle"
Just kidding mate.
welcome to the forums.
it a long running joke about me and scooters.
I'd say it could be fouled plugs or bad fuel too.
Jeffcoslacker would be your best bet. he's got a lot of mechanical experience.
Old 10-29-2008, 02:42 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I presume its a carb, as nobody has an EFI 50cc scooter - yet.
Possibly you have some dirt in the carb float bowl or fuel line which is restricting fuel flow. Your bike may have a sediment bowl or a filter in the fuel line, which need to be cleaned out or replaced respectively.
The float bowl should be removable. A bit of carb cleaner and possibly a bit of compressed air wil clean up the bowl and the jet(s).
However, carbs are quite delicate and easily damaged. Be very careful or leave the repair to a professional if you have never worked on one before.
Old 10-30-2008, 10:37 AM
Torch Torch is offline
Bogging down can be caused by...
- Air filter is clogged.
- Engine is getting too much fuel.
- Ignition system is giving too weak of a spark to properly ignite the fuel in the cylinder.
- Choke system is not fully opening; which leaves you with a bad air/fuel ratio and can cause too much fuel to be getting into the cylinders.
Old 10-30-2008, 11:14 PM
MagicRat's Avatar
Doh!! Thats a good one to check first.
Old 11-01-2008, 01:08 PM
maybe he should upgrade to the 5 port 150cc motor!
Old 11-03-2008, 09:47 AM
richtazz's Avatar
OMG Blayne, that is frickin' HILARIOUS!!!! That's why I love ya brother!!!!
