Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 10-27-2008, 03:25 PM
logman72 logman72 is offline
96 tracker motor problem
my tracker has 190,000 miles. it has been losing power...now, it will start, but will shut off when i accelerate. i replaced plug wires, rotor cap, dist. cap, fuel filter, and still is dead. also unhooked cat. converter and that isnt the problem. any ideas?
Old 10-28-2008, 02:00 PM
ranger88den ranger88den is offline
Re: 96 tracker motor problem
You need to determine if you're losing fuel pressure (pump, regulator, injector, relay)or spark (plugs, wires, dist. cap, coil, crank signal pickup). Any stored DTC s? Good luck
Old 10-28-2008, 11:12 PM
coopdavillage's Avatar
coopdavillage coopdavillage is offline
one other thing you might want to check out is your mass airflow sensor. mine has gone out intermittenly and when it does it causes a loss in power and it dies at times. might be worth checking into.
