Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-27-2008, 01:22 PM
Scrapper Scrapper is offline
AF Premium User
1994 ford ranger
not my truck but i'm asking for a friened her front brakes lock up i told her power booster or ppv. what do all you think? she don't trust anyone.
Old 10-30-2008, 02:28 AM
Davescort97 Davescort97 is offline
Escort guy
Re: 1994 ford ranger
It could be the proportioning valve, but if that were the case I'd expect the rear brakes to lock up instead. There is a one way valve in the vacuum line that runs to the brake booster. You should be able to blow air through it towards the engine. If it blows both ways or not at all replace it. If the rubber brake lines running into the caliper are bad internally they may not release pressure to the calipers. The insides of the piston cylinders could be rusted or rough not allowing the piston to retract back. The calipers themselves may be loose, binding or sticking. I"d take the calipers off and check everything, then if it all looked OK I would replace the booster and check valve.
