Old 03-17-2003, 01:07 PM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
Question Delayed paint problems
I built this kit around four months ago and all was well for a couple of months then it all went pear shaped. As you can see the finish started to develop very fine cracks which can only be seen at certain angles. As far as I can tell I let all coats dry thoroghly before proceeding. The base coat is tamiya silver overcoated with tamiya clear yellow on then a couple of coats of clear auto motive laquer. A far as I can tell all paints should be compatable as they are all acrylic based. I have had odd things happen when you try and mix enamel and acrylic but none when you use the same type of paint. I think the only way to recover this may be to strip it back and start again as im not sure further coats of paint or clear will fix it. Any ideas
Old 03-17-2003, 01:18 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
Did you use Tamiya bottle X-24 Clear Yellow and put Tamiya TS13 Clear spray over it?
Old 03-17-2003, 01:25 PM
simdel1's Avatar
simdel1 simdel1 is offline
from what i have heard (not from experience) mixing different brands of paint/clear coat/laquer can cause problems sometimes.
has the model been left anywhere where it gets very hot, then very cold?
Simon
Old 03-17-2003, 01:27 PM
sugarcaddy's Avatar
sugarcaddy sugarcaddy is offline
Re: Delayed paint problems
This is your problem right there in your own sentence. You sprayed a lacquer clear over a oil based paint. You CAN NOT put lacquer over oil. You can however put oil based paints over lacquer paint.
The lacquer clear reacted with the oil based paint and cracked the paint because of the thinner in the gloss coat.
Your going to have to strip and repaint...
sorry dude
Scott
Fastest hunk of junk in the Galaxy.....
Old 03-17-2003, 01:46 PM
flyonthewall's Avatar
Car Mod guy
The automotive laquers are 'hotter' than the Tamiya ones and will react. Did u lay down the auto laquer in fine mist coats first or just go straight ahead with the wet coat?
Old 03-17-2003, 04:32 PM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
it is sad to see such a cool topline estima have the paint cracked. good luck and redo it......sure it will look better. and I like your rim choice.
Old 03-18-2003, 11:15 AM
Verminator's Avatar
I was under the impression that tamiya paint from jars was all acrylic, is this not true? or are the clear colours different. I have learnt my lessons previously with mixing oil and acrylic mediums but thought I would be ok with this. Would tamiyas own clear be ok as I am planning to use the clear over silver approach again Any further comments appreciated.
ps I usually do several thin coats then a final heavier coat so as far as I can remember I did this kit this way also
Old 03-18-2003, 11:16 AM
djmr2's Avatar
djmr2 djmr2 is offline
the problem is, the JARS are water-based acrylics, the Spray cans are Synthetic Lacquer based acrylic i believe..
Old 03-18-2003, 11:20 AM
Verminator's Avatar
thanks for that, it would explain my problem, i assumed all acrylics were water based so ive learned something new again, thanks for the info, I wont mix my paint types again
Old 03-18-2003, 11:23 AM
ales's Avatar
ales ales is offline
Forza Schumacher
if it's any consolation, I think it looks CL like this!
