Old 10-26-2008, 10:14 PM
jph2424 jph2424 is offline
Door Lock
I have a 1997 Gran Prix Se with power door locks (no remote). When I pull on the door handle on the inside or outside the door will not open unless I pull very gently and even then most times it will not open. If the handle will not open the door I need to hit the open button on the power lock switch and then try again. You don't hear a click when you hit the power door lock switch to lock it but you do when you hit the unlock. I don't know if its the actuator or the power door lock switch. Even when I use the key on the door lock, I have to turn the key and pull the handle up at the same time to try to get the door open. Any help?
Old 10-27-2008, 06:51 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Door Lock
it sounds like a rod inside of the door is out of adjustment. I've never had a rood panel off a GP, but you can take it off and have a look.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-27-2008, 09:17 PM
Re: Door Lock
I took off the panel and also took off the passenger side so I could compare the two. I don't see any difference. The lock cylinder moves a bit but I dont want to get a new one for $60 and then find out it is the actuator.
Old 10-27-2008, 09:31 PM
tblake's Avatar
In God We Trust
Re: Door Lock
get a good used one from Ed Morad at his ebay store
http://stores.ebay.com/Morad-Parts-Company
Send him an email if you dont see one listed, I'm sure he'll have one in stock for a good price.
