Old 10-26-2008, 09:40 PM
noelage noelage is offline
Odd problem - no chimes, no radio
Hi all,
I have a 2000 Sunfire SE. Standard radio - non Bose, non OnStar. A while ago, my radio went - or so I thought. I had some popping from the passenger front speaker. Then, nothing. I have also in this lost the chimes (keys in ignition, lights left on etc.) chimes.
I assumed this was related to the deck, so I went out and purchased an aftermarket deck, with a chime bypass. when I wired everything up, the chime bypass worked - got the chimes from the new box. but, I still have no output from the radio - I have attempted to use both a CD and the radio, and still no output. I plugged the factory deck back in to test, and again no output altogether. I'm at a loss, and have no idea what the problem could be. Any ideas?
Old 10-26-2008, 10:07 PM
Schrade Schrade is offline
Re: Odd problem - no chimes, no radio
No ouputs at all huh? How bout INputs? What kind of voltage is showin' on the power feed INto the deck there?
Old 10-27-2008, 08:53 AM
Power is fine - the radio works, except that you can't hear anything. I have systematically disconnected speakers to break connections, and still nothing. I can not for the life of me figure this out...
Old 10-27-2008, 10:07 AM
I'm kinda' missing somethin' here too...
When you plugged back in the original radio, had you done something that you EXPECTED it to play, or was it just 'plug n pray', see if it went away?
Old 10-27-2008, 10:52 AM
It was plug and pray. In the end, nothing changed. So I'll take the aftermarket and various pieces back, in the end I don't need it - but I'd love to know what is going on with the wiring....
Old 01-18-2009, 09:29 PM
chevygirl03's Avatar
chevygirl03 chevygirl03 is offline
you may have the problem that your speakers are blown. the chimes come through the speakers. replace your speakers and that should fix your problem
Old 01-21-2009, 08:03 AM
Kbrickman Kbrickman is offline
Check voltage into the speakers, as well as the visible wired that lead to the cone and tweeter (make sure the radio is on). Im not sure what the exact voltages should be, but you should be getting sound if its above 0V.
Old 01-21-2009, 03:06 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I'd bet one or more wires are broken where they hinge with the door... the standard radio doesn't have the power output to blow the speakers (unless my previous owner replaced the speakers and not the radio )
Did you try hooking a speaker directly to the radio?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
