Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-26-2008, 05:25 PM
jake54 jake54 is offline
Running Too Cool?
I have a 99 model Dodge Ram 2 wheel drive, 3.9 six-cylinder magnum engine and AT. It has around 86K miles on it. In the 3 years I have owned the truck, the temp guage indicator never gets above 160 degrees. I got to to thinking that this might be affecting fuel mileage. I've never checked the mileage, but I know it isn't very good. Theoretically, would it be more efficient at the 195-200 degree temperature? Any thoughts? Thanks.
Old 11-03-2008, 06:18 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Running Too Cool?
Sounds like the thermostat is stuck open...you might replace it and see if that gets you to normal operating temperatures.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
