Old 10-26-2008, 03:14 PM
scarecrow0529 scarecrow0529 is offline
valve cover bolt torque specs
i know i know buy a damn manual, but in this day and age 18.88 is a lot for a damn book.
Old 10-26-2008, 08:38 PM
RossT RossT is offline
Re: valve cover bolt torque specs
I have the FSM that has the spec, but I am not going to give it to you.
This past winter I changed my gasket out. Got the torque wrench out, sure enough I snapped one.. I replaced the bolt with and extra that I has, and tightend them without the torque wrench to what felt good, and no leaks..
according to the 93 FSM "cylinder head cover nuts = 44 lb.in"
Thats what I used and "snap" so either my wrench is off or the FSM is not correct. be carefull!!
Old 10-27-2008, 01:19 AM
carpenter_jai's Avatar
carpenter_jai carpenter_jai is offline
AF Stunt Driver
I broke a valve cover lid last time I over-torque the nut. I also recommend going by feel. Barely tight should be enough.
Jai
96 3 cylinder Geo Metro (currently being rebuilt)
Old 10-27-2008, 06:35 AM
doug2060 doug2060 is offline
Manual specs:
Valve Cover Bolt 44in. lbs. (5N.m)
Or just get it good and snug...
I used to be bad about getting every bolt and screw as tight as I could. I guess that's why I have about $300.00 worth of extractors, reverse bits and anything you can think of to get out broken bolts. At least I'm good at getting them out...
