Old 10-26-2008, 10:25 AM
1gasenvy1 1gasenvy1 is offline
Coolant tube Replacement
I have determined that water is leaking out of the steel tube connected to the back of the water pump.
Questions?
1. How is that attached to the water pump?
2. How do I get to this part. It seems to be buried under the cylinder head. Do I have to remove the plate that's attached to the front of the engine to remove and repair the leak.
Gasenvy, Proud owner of 3 Geo Metros.
Old 10-26-2008, 01:17 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: Coolant tube Replacement
The O-ring is leaking. There are 2 10MM bolts holding the tube. One under the TB and the other on the side of the trans. Pull the tube out and replace the O-ring. Be sure to lube the O-ring before installing.
Old 10-26-2008, 01:19 PM
Old 10-27-2008, 09:20 AM
Thanks Johnny. This one stumped me. It's very hard to get to and I haven't seen any articles concerning this issue.
I have 3 Metros and life is good.
Thanks for your reply,
Herb(Gasenvy)
Old 10-30-2008, 09:57 AM
Herb(Gasenvy)
Got the tube repaired, It took 3 trys with different "O" rings to get it sealed. BUT...discovered another problem...The head is also leaking. Question? What are the concequences of letting this go. And, what should I do now and i the future?
Gasenvy
(Herb)
Old 10-30-2008, 07:22 PM
If you love the fuel savings from this car, I suggest getting.............
Head gasket KIT
Timing Belt
Timing Belt Tensioner
Water Pump
The job can be done at home with basic tools. We can also help.
Old 10-31-2008, 08:35 AM
Johnny, should I wait until it gets worse? What are the signs of it going south?
Gasenvy
Herb
Old 10-31-2008, 10:55 PM
If you drive short distances with it, then monitor the oil and coolant and run it until it gets real bad. After that, ship the car to me in Ohio and I will make it live forever!
