Old 10-26-2008, 02:43 AM
singring singring is offline
Ignition key won't turn to Lock position
On my 1996 Escort LX, non-tilt steering column, the ignition key won't turn back far enough to LOCK position, and key remains in ignition. I can still turn it forward to engage the starter and drive, but I can only get the key to turn back to the ACC position (1). I have tried dry graphite lube, and failing that I have tried PB Blaster penetrating lube, which didn't work either. Anyone else have this issue? Is there a hidden key release button that I'm not seeing. Ignition worked fine the first 2 weeks since car purchase. Does ignition need to be replaced, and is it easily done? Can a new ignition be keyed to my current key set?
Thanks all
Old 10-26-2008, 08:57 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: Ignition key won't turn to Lock position
I'm sure you've tried this but wiggling the steering wheel back and forth can help. If you have an automatic does it need to be in PARK?
Nevada Tumbleweed
Old 10-26-2008, 07:01 PM
wolfe wolfe is offline
There is a cable that goes from the shifter up to the key switch. Its made so you cant turn the key to lock while driving down the road. It only lets you turn to lock if its in park. If the cable is out of adjustment, you wont be able to get the key out. Fred
Old 10-30-2008, 09:06 AM
msdz msdz is offline
I am sure it is the cable on the shifter out of adjustment or the shifter itself. Maybe try wiggling the shifter or jamming it hard into park.
