Old 10-26-2008, 12:49 AM
fubard's Avatar
fubard fubard is offline
Head Gasket , 2000 Metro
Hello all. I have a 2000 Metro 1.3L, 16V SOHC. I'm removing the head to fix up 1 cylinder which has lost compression. I've ordered a gasket set and it's on it's way. I've started tearing down the motor, getting ready to remove the head. I'm not sure of the socket I need to remove the head bolts. It looks like a 12 PT 11MM socket.I assume that the head bolts are TTY. I haven't removed the timing belt since I haven't quite figured it out. There's a couple more labels on it than on an earlier Metro.The "I" & "E"...intake and exhaust I ass-U-me. I still haven't found the mark on the block & crank gear. I think the block has a small 'knob' on it and the crank gear has a dash on the face .So I assume those need to be lined up.
Am I on the right track? I haven't been able to find a socket yet, no one has a 12pt ...geeez.
thanks
Autos fixed with help from this forum:
1991 Chev Lumina auto engine hurled
1990 Ford Taurus auto death by high mileage
1995 Ford Taurus auto sold !!!
1989 Ford SHO 5 spd, sold, too finicky
1991 Geo Metro 5spd, SOLD, still ran great
2000 Chev Metro auto sold , mileage was poor
1998 Firefly 3 cyl 53mg!! SOLD I don't commute now
1993 Mercedes 300E sold...looking for a newer one
1999 Mercedes ML320
2000 Taurus my wife's new ride. Bought with only 105K
It's almost a fleet !!
Old 10-26-2008, 11:08 PM
sas95 sas95 is offline
Re: Head Gasket , 2000 Metro
Your cyl head bolts are not tighten to yield. The bolts can be reused as long as you clean them up before reinstall, and chase the threads down in the block to clean them up.
You're going to have to remove the camshaft to reach all the head bolts.
You're on the right track.
Old 10-27-2008, 06:37 AM
doug2060 doug2060 is offline
I didn't have to remove my cam...
Old 10-27-2008, 10:00 PM
fubard's Avatar
OK..I think I figured out the cam timing. I put the crank gear on the mark on the block and removed #1 plug to determine TDC with a thin piece of plastic. It seems there is no mark on the cam gear for TDC. I marked the cam gear gear so I could line it up later. I did have to remove the cam gear since the rocker shaft retainer blocked it. So cam is out and I'm ready to remove the head, once I find a socket.
I may replace the water pump , timing belt & tensioner. The prices I got locally were not too bad compared to online sites when I took shipping into account. Afterall, our dollar did take a dump and is still falling ! Unless someone here has a good parts source.
That's good news to hear the head bolts are not TTY!! It makes life easier and cheaper. I'll post some pics of the damage once the head is off. Thanks for the info !
1999 Mercedes ML320
Old 10-27-2008, 10:38 PM
I got all my parts (almost) on ebay. After searching the web forever it was the most affordable option. Waiting sucks though...
Old 10-28-2008, 04:05 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
There should certainly be a timing mark on the cam sprocket, it's the "E" mark. This just showed up at TeamSwift yesterday, just for you I guess.
http://www.teamswift.net/viewtopic.php?f=30&t=40573
The head bolts on every other Suzuki G engine are TTY, I don't see why this one would be any different. Lots of people re-use them but the factory says not to.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 10-29-2008, 12:03 AM
fubard's Avatar
Woodie83, thanks for the reply and link. The pictures don't quite look like my setup. The crank pulley mark lines up with a different mark on the block.Mine is about 20 degrees clockwise of straight up. If I determine TDC on # 1 the crank pulley is lined up with the mark but the cam pulley is 1/2 between the I & E marks. Also, the crank pulley has a pin to engage the belt pulley and no index mark.I would ass-u-me that if I line it up as it was before I took it off it should be fine.Kind of too late now, it's off ...lol. I hope to get the head off soon . I think I found a place to buy a 12pt metric socket...woot.
1999 Mercedes ML320
Old 10-29-2008, 04:15 AM
Woodie83's Avatar
The CRANK pulley has a pin? Usually the cam pulley has a pin (which can be used in either the I or E positions) and the crank pulley has a square key that fits in a slot on the crankshaft and is very prone to shearing, causing the timing marks to be way off just as you describe.
That link is to the proper Factory Service Manual pages, if your engine is different, then something VERY wacky is going on.
Woodie
Old 10-30-2008, 08:47 PM
fubard's Avatar
Yes it has a pin , a small roll pin like the cam gear has. Is there a simple way to verify if the key has broken? The car ran fine on the drive home. Also, I did verify that the #1 intake/exhaust valves are fully closed because all 4 rocker arms are loose ,which as far as I know means #1 is on compression and TDC. As soon as I get some time from work..ughh...and some decent weather I'll get the head off and try to post a pic of the crank gear. Thanks for your replies. I value the input.
1999 Mercedes ML320
Old 11-06-2008, 10:30 PM
fubard's Avatar
I got the head off. I left the intake manifold attached. I found 1 badly burnt exhaust valve in cyl 4 , which was the dead one. I'll take it to the shop and have both exhaust valves replaced and the others checked.So far so good.
1999 Mercedes ML320
