Old 10-25-2008, 11:08 PM
yellowrage yellowrage is offline
oil pressure problem
I just got a 88 crx si it has the 1.6 sohc the block has zc 6132957 can anyone tell by those #s what year the block may be it has mpfi. Next question the head had a noise in it found to be cam gear i replaced it and lost oil pressure it had 50 psi cold 25 hot ideling now 0 i changed the oil and filter with no luck still 0 even if i rev up to 3000 rpm.I was told the bottom end was new..If anyone has any ideas please share them before i pull the motor out thanks..
Old 10-26-2008, 07:23 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: oil pressure problem
How was the cam gear making noise? was it loose?
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 10-27-2008, 09:17 AM
it was a aftermarket gear I'm not sure if they come with a bolt or another washer to use it had started to wear on the key-way i had a friend turn the crank while i watched the the cam gear and seen the play..but after i changed the gear it lost oil pressure so I'm not sure if the cam gear was the problem or if the oil pump was i have it tore down now oil pump out looked at rod and main bearings they look good going to put pump in and see...
Old 10-27-2008, 07:52 PM
Well, if it was wearing around the keyway, that's no good, but I doubt it was making noise...
Usually, if you hear an unidentifiable noise, get a mechanic's stethoscope, and start poking around areas under the hood w/ the engine running. until it gets it's loudest... it's in that area.
Old 10-27-2008, 08:39 PM
thats what i did the only place i could pick the noise up was behind the cam gear i hope to have oil pump in next day or two had to order i'll update when i hear it run again thanks for the input..
Old 10-28-2008, 12:03 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
When a bolt came loose on my b16 the car ran like ass, wouldnt move and make the most horrible clicking noise.. just from loosening one cam bolt, cam never came off either. I couldnt explain it.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-31-2008, 11:59 AM
Ok guys new oil pump in 75 psi cold sound good went for test drive about 5 miles came back about 25 psi hot thanks for the input going to put brakes on now....
Old 10-31-2008, 01:46 PM
25 PSI hot is not good.. it should stay around 40-60 constantly.
You may have worn bearings, you should look into that.
Old 11-01-2008, 06:58 PM
that's 25 to 30 psi hot at ideal i looked at rod and mains they looked good ever thing seems good right now....
Old 11-05-2008, 01:08 PM
eg.ob eg.ob is offline
not true at all.
