Old 10-25-2008, 09:34 PM
dthorn292005 dthorn292005 is offline
1998 Ford Windstar Clock Spring Help???????
Can anyone tell me the steps to fix this problem? My horn and cruise control quit working at the same time and I think this will fix it. Is this the real name for this part?
Old 10-26-2008, 05:18 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: 1998 Ford Windstar Clock Spring???????
dthron
Welcome to AFs!
I bought a damaged 98 that the airbags had deployed. When I got it back together I didn't have a horn or cruse. I too thought it was the clockspring. It turned out to be the fuses. I had a shorted horn that blew the fuse. I think the ABs blew their fuse when they deployed.
Check your fuses.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 10-26-2008, 05:25 PM
Originally Posted by LeSabre97mint
dthron
Welcome to AFs!
Check your fuses.
Regards
Dan
I too thought that it might be a fuse, but they were fine. I'm really not 100% sure that it is the clock spring either, that's just about the only thing I know left to check. Thank you for your reply Dan.
Old 10-26-2008, 06:13 PM
To pull the CS you need to pull the driver airbag after pulling the ground off of the battery and waiting for a min. Pull the steering wheel which the CS under.
Instead of pulling the CS.... you could pull the AB (after pulling the ground on the battery) and check for continunity through the CS by pulling the relay for the horn. There should be a conection between the contacts for the coil of the relay and the wires to the horn button.
Another thought....have you checked the relay?
Dan
SW MN
Old 10-26-2008, 07:30 PM
Dan
Thank you Dan I will check the relay first. Where is it located is it under the hood?
Old 10-26-2008, 09:53 PM
The horn relay is under the dash on the driver side. It should be listed in your owners manual. You could switch a relay with a known good one. Most of the relays are the same.
Dan
SW MN
Old 10-28-2008, 10:49 AM
Dan
Thanks I will check that today.
