Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-17-2003, 10:06 AM
BIGNICKDOG BIGNICKDOG is offline
Question Sil-Eighty project/ Lots of Q's
First off I'm new to this forum
Ok, I would like to build a Sil-Eighty using a U.S. 240sx. I have lots of experiance with working on or building engines. Not so much experiance with body panels and such. without further ado, here are the questions.
1) $$COST$$ How much would it cost to build one of these? Excluding price for a 240sx.
2) How many man hours does conversion take once you have all the parts?
3) Is there ANY CUSTOM FRABRICATION for the body panels that is needed? if so what kind, and how hard was it?
4) *ENGINE* How well does the SR20DET motor fit in the 240sx? Is there less room to work on motor once intsalled compared to stock 240 motor? Is there CUSTOM FRABRICATION needed here at all?
5) I have heard that everything for these conversions is just bolt on. But I have worked on alot of cars and NOTHING ever just bolts together. So what are all the dark secrets and shortcuts for building a SIL-EIGHTY?
Thanks Alot!!
Nick
Old 03-17-2003, 10:24 AM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Re: Sil-Eighty project/ Lots of Q's
well it depends on how much you want to do. There are a ton of things you could change on it from the front end conversion, to the engine, all the way down to japanese vin plates.... I'm guessing that you dont want to go that far though. check out www.unstable-hybrids.com and they have the pieces for the front end conversion along with the sr's if you want to buy one of those also. there are many other sites to buy sr's from and they can easily be found here in this forum.
If your just doing the front end, then you should be able to get it on in a day.
check out this site for instructions on how to do this conversion http://sr20.hybrids.jp/installations...ont/index.html
no custom fabrication and the motor bolts right in using either stock KA mounts or SR mounts. just use whichever are in better shape. check out the faq at www.srswap.com for more info on this swap.
It will all bolt together since it is the same chassis. just check the sites i posted above for more info
Old 03-17-2003, 10:27 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
SIZE=4]welcome!![/size]
well i can help with some of your questions
they sell kits on-line do turn a 89-93 240sx h\b (180sx) into a s-il 180
these kits include front hood, fenders, bumper and s-15 lights
those are the components needed for the extreior.
now for your engine question
the sr20det will fit into a 240sx wid no problems,
the sr20det and the ka24de motor is the same basic size and layout,
now with the sr20det motor they are 3 different motors
the:
s-13 sr20det-205hp - $2500-$3500
s-14 sr20det-215hp(i think) - $3000-$4000
s-15 sr20det-240hp(i think) - $4000-$5000
i recomend the s-13 motor even tho ti has the least hp it you modify this motor it will have the same if not more hp as a modifyed s-14,s-15 motor.
the only real difference is that the s-14 and s-15 sr20det have a better turbo design and the s-15 sr20det uses a t-28 instead of the t-25 used in the s-13 and s-14 sr20det, also the injector varries wit each motor,
but like i said once u modify thhe motor is all the same,
i hope i.ve helped in some ways
i plan to do the same when i get a car
good luck
1
Shift_BOOST
97 s14
Old 03-17-2003, 12:22 PM
Dorikin's Avatar
Dorikin Dorikin is offline
If your doing Drag racing, a KA-T may be the better option actually.....
Derek:word..im debating
//Penner\\ : i'm a master debater
Derek:well youve had a few more years experience than i
Derek: Haha AF Sig Material
Old 03-17-2003, 12:33 PM
The S14 SR uses a T28 compressor also.
Also the S13 SR can flow better than the S14 and S15 SR because of it's high port head allowing a straight shot for the air to the combustion chamber. This is also the reason why the S13 SR has a 7500 RPM redline while the S14 and S15 SR both have 7200 RPM redlines.
agreed
Old 03-17-2003, 01:25 PM
Suislide's Avatar
Suislide Suislide is offline
we really need an FAQ in this forum concerning SR20DET installation and other questions like that. it seems every single day i come in here, there's someone else asking the exact same questions that we've answered 100 times over and over again. i'm not blaming the newbs, although they could take a bit more initiative from time to time to search the forum for the topic they need.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 03-17-2003, 01:42 PM
Dorikin's Avatar
Well, lets make one then.....
Old 03-17-2003, 03:19 PM
I want the "Tail happy", "Snap Oversteer" drift car conversion. S13 front end on a '90 240sx with the SR20DET Redhat motor I do have another question though.
:Are parts OEM and after-market readaly availabe in the US? I dont want to have to pay shipping from japan every time I need a part.
BTW: any body have pics of their own SIL-EIGHTY? Would really like to see what you have done with yours.
Thanks
Nick
Old 03-17-2003, 03:49 PM
yeah there are a lot of us companies that offer SR parts.
www.srswap.com
www.autoimaging.com
www.phase2motortrend.com
http://splparts.com
www.lsauto.com
this list could go on forever
Old 03-17-2003, 04:29 PM
Suislide's Avatar
we COULD make an FAQ...but it would be hard to keep it up as we'd need to bring a mod in here to sticky it for us etc. etc. whatever. we could try.
anyways, i'm shaking my fist at you for stealing my Sileighty idea, bignick. lol just joking, the more the merrier.
-Brian
Old 03-17-2003, 04:45 PM
or Igor could pick one of the many that applied for a mod position for the 240sx forum. I dont see why he didnt pick anybody at all
Old 03-17-2003, 06:13 PM
SiRI's Avatar
SiRI SiRI is offline
Send a message via AIM to SiRI
Re: Re: Sil-Eighty project/ Lots of Q's
Originally posted by J SPEC SilEighty
[b]5) I have heard that everything for these conversions is just bolt on. But I have worked on alot of cars and NOTHING ever just bolts together. So what are all the dark secrets and shortcuts for building a SIL-EIGHTY?
So your saying S13 silvia headlights bolt right on to the S13 chassis that previous had "Pop-up" headlights? Wouldnt there be a cutout for the lights instead of a silvia shaped bracket :o
Old 03-17-2003, 06:18 PM
Suislide's Avatar
i applied...
SiR: the frame is the exact same. with the Silvia front end, there's a bracket you need to purchase with the rest of the parts that holds the fixed headlights in place.
-Brian
Old 03-18-2003, 05:13 AM
turbo2nr's Avatar
i also applied but i dont think im worthy of that position cause im still a newbie but i think it would be a geat idear to have a faq in the 240sx forum because it is true that almost everyday some one comes in and asks the same questions about the sr20det motor and the swap.
So a faq will be great!
:smoker2: :smoka: :smoker2: :smoka:
Shift_BOOST
97 s14
Old 03-18-2003, 05:47 AM
TatII TatII is offline
i don't even think igor checks this forum anymore. this forum use to be dead. i'm actually very glad that this forum is coming back to life. but honestly i haven't seen igor for like 2 years. i think hes too busy chillin at the skyline forums.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
homemade sil-eighty jdmhotrod WIP - Street 10 01-27-2004 08:11 PM
In-class doodle. Sil-eighty nismo4banger Sketching and Drawing 6 12-10-2003 11:59 AM
signal sil-eighty?? turbo2nr Car Modeling 12 08-08-2003 03:51 PM
sil eighty question, NOT covered in faq nightkids013 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 04-13-2003 09:38 AM
Sil-Eighty Sil-Eighty 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 16 11-03-2002 04:08 AM
