Old 10-25-2008, 09:19 PM
Ta-taaa Ta-taaa is offline
Trouble Shooting Heater
I'm new to this site, and if it's as good as the Corvette Forum, I'm sold!
I have a 94 k3500, in great shape. I have not had it very long, but its in great shape.
The Heater and A/C did not work in the truck at first. I replace the Blower motor and got the a/c working.
Now it's cold and I can't seem to get Heat. Raidiator is full of coolant.
I know the heat is controled by a door. I checked the motor on this door and it does not seem to be working when I change the tempeture.
What is this motor called? And how do I do a correct test?
Thanks!!!
Old 10-25-2008, 10:47 PM
Schrade Schrade is offline
Re: Trouble Shooting Heater
Welcome to the no-games boards!
forums.corvetteforum sucks better than
Is the heater core inlet and outlet hose the same temperature?
Old 10-26-2008, 11:09 AM
777stickman 777stickman is offline
This is out of a '98 C/K manual and your '94 may be entirely different. It may be electric, cable or vacuum.
It's called the "temperature door motor". Look for 3 wires at the motor. Black, Brown & Light Blue. Check for a good ground on the Black. Check for 12v on the Brown with the key in "run". Check for voltage variations on the Lt Blue while turning the temp dial with the key in "run".
Also can you control the air flow from floor to vent and in between?
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-26-2008, 12:15 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
If it has five wires it is the temp door motor. lt. green, lt. blue, drk. blue, black, and tan. Lt. green and blue control the motor. The other three determine the doors posisiton.
Old 10-26-2008, 03:22 PM
Thanks for the Replys!
Where is the Temp control door located?
Old 10-26-2008, 04:13 PM
Airjer_'s Avatar
Probably pretty close to the motor!
Old 11-15-2008, 10:50 AM
Got it fixed!! It was the heater core. Totaly plugged.Thanks!
Old 11-15-2008, 12:37 PM
j cAT j cAT is offline
since this is a 94 I have seen this problem were it was the OEM SEALANT tablets that caused this blockage....
if not done you should flush out the entire coolant system and if necessary use a coolant flush chemical...
for some reason the heater core is the first indication of coolant issues...as this gets pluged first...
