Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Classifieds
Old 10-25-2008, 04:16 PM
kjewer1 kjewer1 is offline
AF - Advisor
Shitload of stock and performance parts for DSM and EVO
I'm in central Mass, but the parts are an hour away from me. I make a run out there on thursdays/fridays and can ship those same days.
Buy my shit. I'm a little foggy on what half of this crap goes for, I'll update it as I figure it out. Otherwise make offers. Except on the high value high demand stuff, if there even is any, I'm quite open to getting ripped off to get it gone. Feel free to put in pre-orders for other stuff coming up soon, like DSM FP4Rs, SX pump, RWD's front mount, etc. Tons more coming soon as I organize all of this.
Main link to gallery:
http://s116.photobucket.com/albums/o...rts%20blowout/
As you can see this stuff takes up a lot of room that I need back.
http://i116.photobucket.com/albums/o...Blowout041.jpg
http://i116.photobucket.com/albums/o...Blowout005.jpg
EVO8 HKS 280s. $375.
1988 Mightmax motor, G54B IIRC. Has 44k miles on it. Dealer said it has a brand new head and head gasket installed (which is obvious), but then the PO ran it low oil or something stupid. The dealer thought the oil pump failed. The oil pan is off, but I didn't inspect it. The crank turns freely. Should be a great core, and I can arrange to have Edgar rebuild it. Whole longblock goes as a unit, get all of this shit out of my garage.
http://i116.photobucket.com/albums/o...Blowout001.jpg
http://i116.photobucket.com/albums/o...Blowout002.jpg
Transmission out of the same mightymax. 5 speed. Clutch looked new, this thing should be mint. $150
http://i116.photobucket.com/albums/o...Blowout003.jpg
http://i116.photobucket.com/albums/o...Blowout004.jpg
3 Center diffs. One is missing most internals, the other missing a part or two, the other is complete, but I believe it is the locked up 90 unit out of Erics old car. Or did I give that to Leon? Can't remember. Take one or all of them for whatever they are worth to you. Good cores to make good 4 spiders out of if you've broken spider gears (speed design won't use cases from broken diffs after I cut my SD 4 spider in half), etc. Get these out of here.
http://i116.photobucket.com/albums/o...Blowout007.jpg
Axle, I don't care which one it is, you figure it out and buy it. You know you need spares.
1g coolant reservoir, no cap, free.
http://i116.photobucket.com/albums/o...Blowout008.jpg
2 sets of what I believe to be stock 2g cams. Rusty but came out of running heads.
http://i116.photobucket.com/albums/o...Blowout009.jpg
3 heads. One 2g NT complete, 1 dirty 2g with springs, one clean 2g bare casting. I believe I have the correct caps for the clean head, but probably not the dirty one. Not sure what the going rate is, pull a fast one on me and get them out of here.
http://i116.photobucket.com/albums/o...Blowout010.jpg
2 6 bolt AWD flywheels. I can have Edgar cut these to your specs. Not sure of the going rate, rip me off.
http://i116.photobucket.com/albums/o...Blowout011.jpg
Box full of blown T25s. I don't even know where the fuck these all came from. 20 bucks each for parts or cores. I'd prefer to keep these local, not worth shipping 10 of these things.
http://i116.photobucket.com/albums/o...Blowout012.jpg
2g Infinity amp out of my 2g (cable sold, lolz), cheap aftermarket coolant bottle ($5)
http://i116.photobucket.com/albums/o...Blowout013.jpg
Super low mileage stock EVO8 flywheel out of my car, and random stock EVO8 LICP. $75 and free, respectively.
http://i116.photobucket.com/albums/o...Blowout014.jpg
1 2g and 2 1g intake manifolds.
http://i116.photobucket.com/albums/o...Blowout016.jpg
2 stock EVO8 O2 housings, and one heat shield. $50 each, and free.
http://i116.photobucket.com/albums/o...Blowout017.jpg
2 alternator brackets, Free.
http://i116.photobucket.com/albums/o...Blowout018.jpg
An assortment of 1g motor mount bracketry including one full side mount (use as core for making solid mounts), and one Buschur Racing EVO solid rear mount insert (for the dogbone, press fit). Free to cheap for the 1g stuff, 30 bucks for the EVO mount.
http://i116.photobucket.com/albums/o...Blowout019.jpg
2 91-94 turbo water pipes, 2 2g water pipes. $20 each for 1g, free for 2g.
http://i116.photobucket.com/albums/o...Blowout020.jpg
2 1g O2 housings, 3 2g O2 housings two of which are ported to some degree. Free for the 1Gs, 20 for the 2g, 40 for the ported 2g.
http://i116.photobucket.com/albums/o...Blowout021.jpg
Stock EVO driveshaft, has damage to the yoke. Swap it out and have a spare. $150
http://i116.photobucket.com/albums/o...Blowout022.jpg
http://i116.photobucket.com/albums/o...Blowout023.jpg
Good EVO rear differential. Keep it as a spare for your high HP EVO, they don't last forever. $650.
http://i116.photobucket.com/albums/o...Blowout024.jpg
Expired RCI Platinum 5pt harness. Try for a recert, or add this to your honda for some street cred. $20
http://i116.photobucket.com/albums/o...Blowout025.jpg
EVO starter, needs rebuild (individual parts available from Mitsu, I'm just too lazy). These POSs are 500 from mitsu! $50.
http://i116.photobucket.com/albums/o...Blowout026.jpg
1g MAS, 2g(?) cruise control setup. I Also have a full 2g AC system from the firewall forward, everything! Get this crap out of here. Free.
http://i116.photobucket.com/albums/o...Blowout029.jpg
1 1990 and 2 2g throttle bodies. $20 each, $10 for one missing ISC.
http://i116.photobucket.com/albums/o...Blowout030.jpg
2 90 degree 2.75" silicone elbows. These are the expensive nice ones. This size fits NT throttle bodies! $30 each.
http://i116.photobucket.com/albums/o...Blowout031.jpg
1g ignition conversion for EVO, fully plug and play! No cutting and splicing the wiring harness on your 30k$ car. Get rid of that weak ass EVO setup. You'll want AEM to make this happen. $200
http://i116.photobucket.com/albums/o...Blowout032.jpg
AMS trailing arm bushings for EVO, new in bag! $80 new, $70 here.
http://i116.photobucket.com/albums/o...Blowout033.jpg
26k mile EVO8 turbo, with oil lines/bolts and comp outlet pipe. $200
http://i116.photobucket.com/albums/o...Blowout034.jpg
Stack o WG actuators. Take your pick. Free.
http://i116.photobucket.com/albums/o...Blowout036.jpg
1g, 2g, and fancy EVO fuel rails. $80 for EVO rail, has 1/8th NPT pressure port and AN fitting on one end. Stock 450 injectors. Aeromotive AFPR all setup for use on EVO, might also work on 1g/2g rails have to check. Black nylon ultralight hose and black fittings, stealthy. Just needs guage. $150.
http://i116.photobucket.com/albums/o...Blowout037.jpg
1988 Mightymax engine harness and ECU. Harness $40, ECU $50
http://i116.photobucket.com/albums/o...Blowout038.jpg
Stock unopened Mitsu pressure plate for NT 1g. $70 new, $50 here.
http://i116.photobucket.com/albums/o...Blowout039.jpg
Mightymax radiator in excellent shape. $50.
http://i116.photobucket.com/albums/o...Blowout040.jpg
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-26-2008, 10:17 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Shitload of stock and performance parts for DSM and EVO
Very nice. Shame I can't use any of this. I see the NT head, no block laying around?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-26-2008, 12:36 PM
AF - Advisor
Nope, no blocks. The head is just a left over from when my brother used to rebuild and resell 2Gs he bought cheap with broken tbelts, etc.
Kevin Jewer
Old 10-30-2008, 02:54 PM
AF - Advisor
List updated. Lost sold, but this list is still way too long...
Kevin Jewer
Old 10-30-2008, 03:27 PM
david-b's Avatar
Dave is THAT guy
I know it's not listed and I don't seen any in the pics, but doesn't hurt asking... any 2G rack and pinion units?
75 Monte Carlo
Old 11-01-2008, 05:51 PM
AF - Advisor
No sir.
Kevin Jewer
Old 11-02-2008, 07:37 PM
AF - Advisor
Here's an updated list, with some price drops, and reorganized.
EVO:
EVO8 HKS 280s. $375
Super low mileage stock EVO8 flywheel out of my car $75 I can have Edgar cut this for your no-down-time-clutch-swap pleasure.
2 stock EVO8 O2 housings, and one heat shield. $50 each, and free. Use as a core for porting or coating and sell your stock one, no down time FTW.
Stock EVO driveshaft, has damage to the yoke. Swap it out and have a spare. $150 I'll do a combo deal with the rear diff.
Good EVO rear differential. Keep it as a spare for your high HP EVO, they don't last forever. $650. I'll do a combo deal with the driveshaft.
1g ignition conversion for EVO, fully plug and play! No cutting and splicing the wiring harness on your 30k$ car. Get rid of that weak ass EVO setup. You'll want AEM or a 2g ECU conversion to make this happen. $200
AMS trailing arm bushings for EVO, new in bag! $80 new, $60 here.
EVO fuel rail. Has 1/8th NPT pressure port and AN fitting on one end. $50
DSM:
2g NT complete head. Not sure what the going rate is, pull a fast one on me and get it out of here.
2g Infinity amp out of my 2g (cable sold)
2 mildly/moderately ported 2g O2 housings from way back in the day. 20$ each.
MightyMax:
1988 Mightmax motor, G54B IIRC. Has 44k miles on it. Dealer said it has a brand new head and head gasket installed (which is obvious), but then the PO ran it low oil or something stupid. The dealer thought the oil pump failed. The oil pan is off, but I didn't inspect it. The crank turns freely. Should be a great core, and I can arrange to have Edgar rebuild it. Whole longblock goes as a unit, get all of this **** out of my garage. FREE for pickup.
Transmission out of the same mightymax. 5 speed. Clutch looked new, this thing should be mint. $125 picked up. These things are rare, I'll crate it up if long distance buyer arranges shipping.
Misc:
Kevin Jewer
Old 11-05-2008, 09:46 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Happen to have a resistor box for the injectors?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-08-2008, 02:44 PM
AF - Advisor
Hmm, nope, not one that's doesn't already have a home on some project. Here's an updated list.
EVO:
EVO8 HKS 280s. $375
Super low mileage stock EVO8 flywheel out of my car $50 I can have Edgar cut this for your no-down-time-clutch-swap pleasure.
2 stock EVO8 O2 housings, and one heat shield. $40 each, and free. Use as a core for porting or coating and sell your stock one, no down time FTW.
Stock EVO driveshaft, has damage to the yoke. Swap it out and have a spare. $100 I'll do a combo deal with the rear diff.
Good EVO rear differential. Keep it as a spare for your high HP EVO, they don't last forever. $550. I'll do a combo deal with the driveshaft.
EVO starter, needs rebuild (individual parts available from Mitsu, I'm just too lazy). These POSs are 500 from mitsu! $30.
26k mile EVO8 turbo, with oil lines/bolts and comp outlet pipe. $150
EVO fuel rail. Has 1/8th NPT pressure port and AN fitting on one end. $40
Aeromotive AFPR all setup for use on EVO, might also work on 1g/2g rails have to check. Black nylon ultralight hose and black fittings, stealthy. Just needs guage. $140.
DSM:
2g NT complete head. Not sure what the going rate is, pull a fast one on me and get it out of here. $50?
Box full of blown T25s. I don't even know where the fuck these all came from. 20 bucks each for parts or cores. I'd prefer to keep these local, not worth shipping 10 of these things. $50 for the whole lot of them.
2g Infinity amp out of my 2g (cable sold). $20
2 1g intake manifolds ($20ea).
MightyMax:
1988 Mightmax motor, G54B IIRC. Has 44k miles on it. Dealer said it has a brand new head and head gasket installed (which is obvious), but then the PO ran it low oil or something stupid. The dealer thought the oil pump failed. The oil pan is off, but I didn't inspect it. The crank turns freely. Should be a great core, and I can arrange to have Edgar rebuild it. Whole longblock goes as a unit, get all of this shit out of my garage. FREE for pickup.
Transmission out of the same mightymax. 5 speed. Clutch looked new, this thing should be mint. $100 picked up.
Misc:
2 90 degree 2.75" silicone elbows. These are the expensive nice ones. This size fits NT throttle bodies! $25 each.
Kevin Jewer
Old 11-25-2008, 03:47 AM
AF - Advisor
Updated list:
Buy my ****.
EVO:
DSM:
Kevin Jewer
Old 12-11-2008, 04:11 PM
toymaker3000gt toymaker3000gt is offline
if your looking for 7-bolt block i have one just let me know if your interested!
garydowless/@ myspace.com
Old 12-14-2008, 11:13 PM
DSM96GS's Avatar
DSM96GS DSM96GS is offline
how much for the 2G n/t head and how many miles are on it.
Is the clean 2G head N/t? If so how much for that too
