95 Buick Park ave brake line blow out
I had a emergence stop on Friday and had a brake line blowout so I guess its time to do some plumbing. Now before I get into it I was hoping for some golden nuggets of wisdom on the dos and don'ts anything that you have run into that might make my job go a little smoother.
Re: 95 Buick Park ave brake line blow out
Get the newer coated brake line to prevent rust thru issues, assuming you are talking about the steel line, try to prevent draining the m/c down while doing the job, this will make bleeding more difficult. Block off the open line some how while fabricating the replacements. I use a tightly fitting vacuum port block off cap.
maxwedge your tips where very helpful the job went very smoothly I had a bit of a of a problem with the rear valves and a wheel cylinder but other then that it was good. Thanks again!!
