Old 10-25-2008, 06:27 AM
kennett04261988 kennett04261988 is offline
clutch problems? need help!!!!
so my clutch doesnt engage till about the very top of me releasing the clutch is this normal for a 3000gt or wat? do i need to just bleed it or do i need a new clutch or wat? i dont feel a loss in horsepower. sometimes the clutch slips but i bought a new clutch already but before i put it in i want to make sure i dont need to replace any other parts that may be causing this problem. so my main ? would be: is it normal for my clutch to engage almost at the top of the clutch release pedal or no? and if its not normal wat is causing the problem???
blaine
Old 10-25-2008, 09:31 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: clutch problems? need help!!!!
It might just need adjusted. You'll have to crawl under the dash and there is a locknut on the clutch pedal assembly. Loosen it then spin the rod. I cant remember which way will adjust it down but you will probably have to adjust it a few times to get it to a feel you like.
