Go Back   Automotive Forums Car Chat > Peugeot > 406
Old 10-25-2008, 03:08 AM
paul247 paul247 is offline
406 braking judder
changed pads on front discs,got this judder (only now and then)so change discs still the same ,had them off 6 times cleaned and removed any dust and pads not tight but still the the same?
Old 12-01-2008, 11:53 AM
evo2000 evo2000 is offline
Re: 406 braking judder
Hi, Did you resolve the problem, I take it you put new pads on again when you chnaged the discs, I have the same problem, I am chnaging all the bushes on the front this week and hope this will fix it. Mine is only a slight judder you can feel though the peddal. is strainge.
Old 11-16-2010, 02:49 PM
betuaintgotthis betuaintgotthis is offline
Replacing the discs should have eliminated any brake judder but since you still have it might be worth swapping tyres around as you might have a soft spot. Also check for worn bushes/joints etc
