Old 10-24-2008, 06:28 PM
p1vanzan p1vanzan is offline
Ignition Switch Question
I removed my old ignition switch and am ready to install the new one. The problem is I can't get the three wire connection out of the old switch. Do I have to have this hooked up or can I go with out it? Is that for the Passlock feature? Any help would be appreciated as I would like to get my car back together ASAP. Thanks
Old 10-24-2008, 11:01 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Ignition Switch Question
7. To remove the lock cylinder, put the key back in, turn it to the ON position, or second click, and then locate the little metallic tab on the switch. I honestly cant remember where it is, but its the only tab on there. You push that tab in while pulling on the key and it should slide right out.
8. The switch should be fully free now, as that last connector essentially falls out without the lock cylinder in place, but take notice of how it works so you can put it back together when the time comes.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 12-01-2008, 05:06 PM
So I got my new ignition installed and it works, but when I hook up the park/lock cable it won't allow me to get the key back out. Is there something I am doing wrong? I don't want to put the dash back together until I have this figured out. Thanks
Old 12-08-2008, 04:25 PM
Bump
Old 12-09-2008, 06:22 AM
Hoppy2 Hoppy2 is offline
Not sure? Did you put the interlock cable in properly? It only snaps into the switch. Maybe it is not seated correctly.
Old 12-10-2008, 01:50 PM
It snaps in, it just won't let me remove the key once it is clicked in place.
Old 12-11-2008, 06:47 AM
What if you don't put the cable in. Does it work then? If so, just leave the cable out, as long as you can still shift.
Old 12-11-2008, 10:33 AM
LittleHoov's Avatar
Sounds like something in the lock cylinder to me, it would almost have to be installed properly to start the car though.
What about that little tab that you push in to remove the lock cylinder? Its not stuck in is it?
This is really strange and is probably something simple, I guess if worse comes to worse you can just get a new ignition switch.....or get a spare key and leave one in the ignition
