Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-24-2008, 02:46 PM
hilts2000 hilts2000 is offline
99 Camry stuck in park and won't start
My engine light came on yesterday. This morning I could not start the car. I jumped the battery, got it started and it ran for a while. I pulled the alternator and battery, both tested fine. I started the car back up but lost all my dash lights and now can't shift out of park!! Help.
Old 10-24-2008, 03:04 PM
somick's Avatar
somick somick is offline
Re: 99 Camry stuck in park and won't start
How did you test your alternator and battery?
And you of course need to read the code. A good code reader will read codes even on non running car.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 10-24-2008, 03:11 PM
I took the alt and battery to O'reily's they checked them out as OK. I was going to drive back up and check the engine codes, but couldn't shift out of park to go check the codes.
Old 10-25-2008, 02:35 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Have you tried the shift override switch? Don't recall the procedure but you remove the little cover just forward of the shifter and press the button. Check your drivers manual. That button is there specifically for when you can't shift out of park. The shift interlock system needs power to operate. If you loose power the default mode may be you can't shift out of park. Not sure.
If you don't have a driver's manual you'll find a copy in the Factory Service Manual thread at the top of the forum.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-27-2008, 11:13 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
There is a park/neutral safety switch that prevents starting the vehicle unless it is in Park or Neutral (duh). I'd have that checked as well as another switch (for the stop lamps) down on the brake pedal that is required to be depressed before you can shift out of Park.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-27-2008, 12:19 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
I have replaced a bunch of those in the last couple of months for some reason!
