Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-24-2008, 01:03 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Synthetic Trans Fluid. switch to or not.
I am getting ready to do a trans fluid and filter change on my 200R4 with 103000 miles on it.
I am not having any trans related problems but was just wondering if there would be any advantages in switching to a synthetic trans fluid with a trans this old?
Any input would be helpful.
Al
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-24-2008, 04:05 PM
Schrade Schrade is offline
Re: Synthetic Trans Fluid. switch to or not.
Al
I think doin' regular fluid / filter change does more good than anything. Synthetic won't hurt I'm sure, but probably isn't necessary, unless you keep the pedal on the floor.
Old 10-24-2008, 06:53 PM
mega420 mega420 is offline
Send a message via AIM to mega420
i personally would use just regular fluid unless you beat the living hell outta it. then use some b&m trick shift
Old 10-26-2008, 10:45 PM
Blt2Lst's Avatar
I forgot about the trick shift, is that a synthetic?
I was thinking about the Royal Purp.
In the end, i will probably use the the regular stuff.
Thanks for the input.
Al
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 10-27-2008, 10:48 AM
SLJ2137694 SLJ2137694 is offline
DEXRON VI is the latest fluid spec and it replaces all previous DEXRON fluids. There may still be some old DEXRON III sitting on the shelves.
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
Old 10-28-2008, 05:17 PM
the b&m comes in synthetic and non. i used a 25% mix in my last caprice and it shifted real nice but as for synthetic tranny fluid if your gonna spend the money on it just get the royal purple it is a great name and fluids. i personally know the oil will give you 8 plus extra hp in the motor but for tranny idk. cant hurt to use thou
Old 10-28-2008, 05:57 PM
j cAT j cAT is offline
dexronVI is now the only transfluid that is available for a direct replacement for dexron III...this is a synthetic mix...
The other option that I took several years ago was to change over to the Mobil synthetic trans fluid...
results of that was faster shifting especially at 0 deg F....faster engagement forward to reverse.... greater roll going down grades on hywy..
slight MPG improvement..supposedly it reduces the trans temp...
Old 10-28-2008, 06:02 PM
i belive thats what the b$m regular does so the synthetic must be alot better
