| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
1990 gsx that won fire.
ok i have a 1990 gsx that fire. i have read all the post but none of them have went through this. i have put three coil packs on it, along with three power transistor's and two cam/crank sensors and a computer. my friend said maybe a sensor on the turbo, if anyone can help it would be greatly appr. i have also checked all the fuses i can find, is their more than under the hood?
Re: 1990 gsx that won fire.
It was a bit hard to read but from what I gather you can't start your GSX. How do you know it's an electrical issue? We need more detail. What did you do that may have caused the issue? We can't help you w/out more detail.
well the reason i think ele. is because it has a new fuel pump and it is getting fuel all the way to the fuel rail. when i took off a plugwire their was no spark. my cousin told me it was running when he washed the moter off. then it went dead and wont start back. like i said i have tried everything i know to try.
Kipsplace1956, I deleted your post here because you made a thread with it and didn't have anything to do with the original post. Just letting you know why it's gone.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
like the other person said we need more info. does the cars ignition turn on? does the car turn over but not start?
three things for fire. fuel( you say you have) air, and spark. if the car cranks take out one spark plug wire off the spark plug. insert a small jumper wire ( a piece of wire with both ends bare about 6 in. long) have some one turn the car over while you hold is close to bare metal on the engine. Start by touching the metal then back away slowly to no more than an eighth of an inch. Do you see spark? do that with the other three and then report back. that is if the car turns over. |
