Old 10-24-2008, 12:14 PM
chrissbee77 chrissbee77 is offline
Question fuel question
I have a 2001 grand pridx 3.8 n/s and was just wondering if 355-371 is about right for a full tank of gas. i know that depends on tune up and how i drive just wanted someones opinion. i dont dogg it out and just replaced the air filter full tune up and fuel filter just thought i should be getting more mpg
Old 10-24-2008, 12:40 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: fuel question
355-371 miles per tank? I would say thats pretty much the norm.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-24-2008, 02:22 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: fuel question
are you talking highway or city? i know on the highway with my GT i usually get around 34 MPG, and in the city usually right around 25. but yeah, for hwy right around 370 miles for a full tank of gas sounds right.
you can always check your MPG by filling up your tank, once its close to empty....fill it again and see how much fuel you used, then divide the miles you went by how many gallons of fuel used, theres your MPG
Old 10-24-2008, 02:33 PM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: fuel question
Sounds about right. I can stretch mine to 400 but why?
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 10-26-2008, 02:41 AM
doctorhrdware doctorhrdware is offline
Re: fuel question
With my gp I get around 420 to a tank full, that is with out streching it. I am getting close to 32MPG. But it will very between 28 and 32 MPG.
Old 10-27-2008, 06:48 AM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: fuel question
wow, I wish I got that out of mine.
I get about 16.6 to the gallon.
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 10-27-2008, 07:26 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: fuel question
Is that highway or in city? Too good for "in city only" and 20-22 on a GP equipped with a NA SII 3800 engine is normal. It should be higher for highway only like when traveling. Combined varies.
Timeslip 08/12/06
AF Community Guidelines
Old 10-27-2008, 11:14 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: fuel question
I get 21-22 around town in my 99 GT and highway mileage varies quite a bit depending on speed.
I recently took a trip and did a little experimenting with very interesting results which actually validated what I thought before I started.
Once on the highway and at cruising speed, I reset the DIC at different speeds to see what effect it had on MPG.
At the start of the trip fully fueled in Michigan, I set the cruise at 75 mph (any less and you'll get run over on US-23) and got 27.4 mpg. I hit the Ohio border and dropped the cruise to 68 mph and reset the DIC and was getting 33.6. As i got further south where traffic was moving faster, I bumped it up to 72 mph, and still was getting 32.8. I filled up for the return trip home and repeated the experiment, and even with a full tank, I got 32.6 at 72, and still hit 33.5 at 68 mph, and dropped again to 27.6 doing 75 mph in Michigan. By this experiment, it seems these cars hit an aerodynamic wall at about 75 mph which affects economy quite a bit. Keep in mind that each figure was attained after a distance of at least 90 miles, some a little more, so I believe they are pretty accurate according to the DIC mileage indications for comparison purposes.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-27-2008, 01:34 PM
Re: fuel question
i did sort of the same thing with my GT. sounds about right. when i got on the 2 lane roads up in the UP Michigan and set the cruise to 62, my DIC said i was getting 35.6 MPG. here in WI the speed limit on the freeway is 65, if i set the cruise at 72, the DIC said i was getting 28.3 or something like that.
Old 10-27-2008, 01:36 PM
jessep28's Avatar
jessep28 jessep28 is offline
Re: fuel question
I get about 19-20, but about 60% of my commute is in stop & go traffic.
00' Pontiac Grand Prix GT
83,500 mi
Old 10-27-2008, 03:35 PM
Re: fuel question
That is both city and highway. In city it is usually around 23 give or take.
wlkjr's Avatar
Re: fuel question
I was going almost 75 but the DIC only wrote me up for going 68.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
