Old 10-24-2008, 10:02 AM
mldlawn mldlawn is offline
Angry crank shaft sensor?
does any one know where the crankshaft positon sensor is on a 1998 cavalier 2.2? please help
Old 10-24-2008, 12:19 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: crank shaft sensor?
Under the module or close buy.
Old 10-24-2008, 01:43 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Umm... no..
Back of the block driver side...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 10-24-2008, 08:58 PM
Airjer_'s Avatar
Originally Posted by Classicrocjunkie
Umm... no..
Ummmmmm Yeah! Thats where the bracket for the module is bolted to as well!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-25-2008, 06:14 PM
Lifted GMT-360!
95-97 yes..
He has a 98... 98-02 are mounted on the side of the head. ( Note placement of RED MSD coil pacs)
PWND.
Old 10-26-2008, 05:35 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I always hate arguing about something I'm not sure on... but since when is the crankshaft in the head or accessable from there? The module can be (and usually is on most engines) seperate from the sensor.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-26-2008, 10:12 PM
Lifted GMT-360!
No one said the CPS was in the head. It is on the back of the block.
I am arguing with Airjer_ about the placement of the ignition control module. He seemed to think the ignition control module on a 98 was located there. In which is it not.
Did i clear up any confusion?
Old 10-26-2008, 10:30 PM
Airjer_'s Avatar
Yup that was my bad! I was thinking that they didn't switch until later (for some reason I was thinking it was 2000? Hey, I'm blonde I can get away with that!!)
The crank sensor is still in the same place, ibn the back of the block. GM just changed the location of the module and coil packs.
Old 10-27-2008, 04:34 PM
J-Ri's Avatar
Yup!
Sometimes I read faster than I probably should
