Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 10-24-2008, 08:43 AM
eric1h eric1h is offline
Anyone know the part number for the shifter pivot ball?
I have some play in the pivot ball on the shift lever, not the one in the transmission, but the ball in the shift lever/handle
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 10-24-2008, 11:24 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Anyone know the part number for the shifter pivot ball?
I've got the full GTS parts list and the GTRA parts list at home in my Panoz binder. I'm working until 9 tonight, but can look it over. If you search the early threads on here you'll find links for both.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 10-24-2008, 05:41 PM
panozracing's Avatar
panozracing panozracing is offline
11 -- PZR7-6408 Bearing – Misaligned Spheric
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 10-25-2008, 04:20 PM
Thanks!
Old 11-14-2008, 09:04 PM
So as an update, i put a new Steeda Tri-ax shifter in the car, turns out it already had a HUrst SS in it, and the pivot ball isolator cup was worn out, so I ordered a new brass one to upgrade from the crappy plastic one.
MAN what a difference!!!
