Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Calibra
Old 10-24-2008, 05:45 AM
bantamjack bantamjack is offline
Question no compression in calibra
Help!!
I have just done the hydraulic lifters on my Holden (Opel) Calibra, put it back together and it started first kick. The timing was out a tooth on the exhaust cam though so I did it again.
Of course the inevitable happened and the belt slipped, I lost the timing completely and have now no compression. I tried the timing 180 degrees from where it was but still nothing. This process has been repeated several times.
The engine turns over too quickly indicating that I have lost compression.
The questions are:
Could I have bent a valve (or valves) by turning the engine over when the timing was out, usually no more than a tooth or two.?
Is it possible for the piston to contact a valve (or valves) by turning it over when the timing is out. Id this is so it would it bent the valves?
Any advice asap would be greatly appreciated.
Bantamjack
The Following User Says Thank You to bantamjack For This Useful Post:
TehranSD (12-17-2015)
