Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-24-2008, 02:39 AM
Speedy Mike Speedy Mike is offline
98 RS Start Issue
I have a 98 Eclipse RS with a 5 speed manual. It wont start by turning the key. There is a clicking from behind the radio from the starter relay. The engine starts when you pop the clutch and also starts when you jump out the selenoid. Also the battery tends to go dead. This problem just occured the other day. There is no alarm system or anti theft system on this car. I did clean the contacts on the battery. But have not checked the negative contact to the transmission since the car does start fine when the selenoid is jumped out. Also have not checked the clutch safety switch. Any other idea what might be causing the car not to start?
Old 10-24-2008, 02:44 AM
Re: 98 RS Start Issue
When i say it wont start. I mean the selenoid wont click unless it is jumped out.
Old 10-24-2008, 08:41 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Replace the battery. Mine did the same. Turned out the battery was shot.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-24-2008, 02:18 PM
ned032002's Avatar
ned032002 ned032002 is offline
Changing the battery is a relatively cheap replacement so try that first then see what happens.
Old 10-25-2008, 10:05 PM
yea thats not the issue. battery is fine. I hear a faint buzzing sound and there is a dead short somewhere in the wiring. When I check the resistance between the right male contact at the fuse for the ignition switch there is resistance. And the buzzing goes away when the fuse is removed. doesnt make any sense...
Old 10-27-2008, 09:48 PM
combination of problems, it turned out to be a push thru button that prevents the neutral safety switch from breaking when the clutch is pressed to hard. and the battery was to dead to start when i tried holding the switch down by hand. Car starts perfect now.
Old 10-27-2008, 09:54 PM
This is a fuseable link. its not soldered in.
Old 10-27-2008, 09:58 PM
wrong forum.. lol opps
