Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 10-23-2008, 08:34 PM
rimirilar rimirilar is offline
oil leak, carburetor fire
Ok, so I had a bad oil leak and thought it was the rear main seal. After tearing it apart and seeing a good seal, I replaced it anyway, and the oil pan seal. It still leaked. I replaced the valve cover gaskets. Still leaked. I took off the intake manifold and replaced the seals and added new RTV. Now it won't start. I reset the cylinders so that the No.1 is up, and the distributor is back on the exact way it was taken off, and I have rechecked the plug wires. I made sure that the floats in the carb hadnt somehow gotten stuck up. So far I have only successfully caught the carburetor on fire. Twice. What am I doing wrong? Does anyone have any suggestions? I dont even know if it still leaks because it only does it while running and for a little while after it has been turned off.
Old 10-24-2008, 10:28 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: oil leak, carburetor fire
Year & engine?
Sounds like you're 180* out or the valve timing is still wrong.
Old 10-24-2008, 03:26 PM
It is an 87 Formula. It has a 305 with a 750 Holley 4 Barrel. The choke is manual, which is good because I closed it to put out the two fires.
Old 10-24-2008, 03:27 PM
It is an 87 Formula. It has a 305 with a 750 Holley 4 Barrel. The choke is manual, which is good because I closed it to put out the two fires. If I am 180* or the valve timing is wrong, do you have any suggestions on how to fix it?
Old 10-24-2008, 03:37 PM
wrightz28's Avatar
From the sounds of it, you have #1 at TDC, but on the exhaust stroke
Old 10-26-2008, 01:23 PM
How should I correct it?
Old 10-26-2008, 08:42 PM
mikeemon's Avatar
mikeemon mikeemon is offline
Reinstall Distributor at #1 tdc on compression stroke.
Old 10-26-2008, 09:30 PM
Thanks I'll give it a shot. I thought that is what I did, but I guess I did it wrong. I'll post again if I cant get it, or it still doesnt work.
Old 10-26-2008, 10:54 PM
Ok, so I got it tdc, on the #1 cylinder, on the compression stroke. Still nothing. I am getting little puffs coming out the carb, and the occasional small attempt for it to start up, but still nothing. I almost want to pay someone to do it, but I hate doing that, because not only do I like doing it myself, but it also furthers my knowledge in automechanics. I have been going at it off and on for a week and a half. I have killed a battery. I am at a wall. Any more suggestions?
Old 10-27-2008, 09:32 AM
MrPbody MrPbody is offline
AF -Advisor
How are you determining you are actually ON the "compression" stroke? Simply lining up the timing mark won't do it. You must remove #1 plug, put a finger in the hole, "bump" the starter until compression pushes your finger off. Then, with a wrtench, rotate to TDC by the mark. Then you KNOW you're "up" on 1.
The symptom you describe is that of an engine with the distributor 180 degrees out.
Also, verify your wires are in the right sequence (1-8-4-3-6-5-7-2), clockwise rotation.
Jim
Old 10-27-2008, 06:05 PM
I have been turning with a wrench until compression is felt. Just so I am doing it right, compression is felt by a puff of air coming out of the #1 plug hole, right? Do I have to bump the starter to get it, or will doing it this way work?
I numbered all the plug wires with the spot that they correspond with on the distributor cap. I numbered the distributor cap also, so that I knew there would be no mistake of where they came off from.
Old 10-28-2008, 08:27 AM
AF -Advisor
That SHOULD do it, feeling the compression by "hand". Are you also assuring the rotor is pointing AT #1 (on the cap) once you've found TDC? Based on your initial post, this COULD be the problem. The rotor should point at #1 wire, not "where it came out". Once you move the engine, the original position of the rotor is meaningless.
Jim
Old 10-28-2008, 11:10 PM
It is pointing at the #1 wire. I am starting to wonder if maybe somehow something didnt go wrong with the carb. If somehow the floats in the carb are stuck in the up, do I have to take the carb apart to get them down? I tried tapping the part of the carb with the bowl's, with the handle of a screwdriver, but I dont know if it did anything.
Old 10-29-2008, 09:15 AM
AF -Advisor
Adjusting the floats in a Holley are the easiest of any carb out there. You need a flat screwdriver and a 5/8" wrench.
Make sure the carb is level. Remove the brass screws in the sides of the bowls (1 at a time). If fuel "weeps" over the edge and runs out, but doesn't POUR out, the float is right. If it pours out, or isn't to the edge, you'll need to change the setting.
To change it, loosen the screw on the top of the bowl, but just a little. Turn the nut with the wrench. Clockwise to lower the float, counterclockwise to raise it. It helps if the engine will run, or you have an electric fuel pump. If not, you're kinda "shooting in the dark".
Since this is an '87, which had furl injection and an in-tank pump, has that been modified? Or are you still using the stock pump? If so, fuel,pressure can be too high, "blowing" the needle off the seat. An "inline" regualtor can fix that.
Old 10-30-2008, 12:52 PM
wrightz28's Avatar
87's were the last year that came with carbs too.
If it did, and you replaced the ECU controlled carb (E4MC or something like that don't remember the exact accronym) how did you remove the ECU from the picture entirely?
