Old 03-17-2003, 07:10 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
starting problems......again....HELP!!!
wassup guys....
I'm having starting problems again. You guys always seem to know what's wrong. You've helped me get my car fixed 3 times. But here I am once again......
Alright so heres the story....
I go to start my car this morning and the damned thing won't start. It clicks but won't start. So I ask my next door neighboor to give me a boost cuz I just figured that I had left my lights on overnight or something. So he gives me a boost....the car starts right up no problem. So then I let it run for 10 minutes, periodically revving it to charge the battery. Then I unhook the booster cables and the car still runs. So i shut the car off, go to start it and it just clicks again. So I pull out my trusty ol' multimeter and my battery is fine...it's giving off 12.3 volts. So then, why doesn't my car start?
I also checked my connections. They appeared to be fine, but it was just a quick glance. I also sanded down both my terminals to a brand new shine. I also sanded down my ground to a new shine as well....but It didn't help at all.
Please help....
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-17-2003, 07:13 AM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
does if click every time that you try it?
This is the real melt pizzle
Old 03-17-2003, 07:17 AM
bambam89lx's Avatar
AF - Advisor
yah it clicks.....but it doesn't turn over. If I keep turning the key for like 10 seconds....it doesn't click anymore...it just sounds like the battery is dead. but it's wierd cuz when I hooked my battery up to my neighbor's battery, the car started right up with one quick turn of the key....
Old 03-17-2003, 07:20 AM
Civic Rush's Avatar
this sounds like a battery problem. you need to get the load checked on it. You need to drive it man. Letting it run works to charge the battery but what you need to do is get it on the road and see how it acts
Old 03-17-2003, 07:22 AM
bambam89lx's Avatar
AF - Advisor
the battery is brand new. I was just driving the car last night for 2 hours straight.....I also checked the battery and it was giving off 12.3 volts....
Old 03-17-2003, 07:24 AM
Civic Rush's Avatar
check the connections that goto the starter and all of the grounds. How old is the alternator
Old 03-17-2003, 11:05 AM
gregc gregc is offline
I have the same problem with my '89 SI......new battery, new alternator.....still does it from time to time......I was told it may be a bad "main relay".......does anybody know where that is?
Old 03-17-2003, 12:00 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Under the dash on the driver side, almost right under the coin tray.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
Re-starting problem...again...again Gems Impala | Impala SS 3 04-23-2007 08:26 AM
Clio DCi 80 Starting Problem again hundleton1 Clio/Clio II/Clio III 1 04-15-2005 05:44 PM
97 JGC starting problem again leosalchemist Grand Cherokee | Grand Cherokee SRT8 2 09-26-2004 03:40 PM
Starting problems... again.... DaPCWiz Maintenance 1 02-16-2002 08:31 PM
