Old 10-23-2008, 12:29 PM
fmercado19 fmercado19 is offline
Engine Swap
I have a 91' honda civic dx (non-vtec) 1.5l. I want to swap it with a 95' honda civic 1.6l vtec engine. I have the vtec computer for the new engine and also a conversion kit as well.
Old 10-23-2008, 12:40 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Engine Swap
search.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-23-2008, 03:56 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: Engine Swap
And when you're done w/ that, don't come back and say "The search didn't work"... search some more.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 10-23-2008, 04:50 PM
FrodoGT's Avatar
Re: Engine Swap
Been covered dozens of times, i did it, and I had multiple sources to choose from.
Current project:
Rio Red 91 hatch.
Old 10-23-2008, 05:14 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Engine Swap
Whats the question again? I missed it in the first post. Sounded more like a statement to me than a question.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-23-2008, 07:34 PM
Re: Engine Swap
Tony, I see your point... there was no question.. that makes this a... Hopes and Dreams thread?
If that's the case, I have nothing to say here.
If that ISN'T the case.. I still suggest the OP Ask Jeeves, he knows all.
Last edited by Christ; 10-24-2008 at 06:36 PM. Reason: To appease BLU CIVIC's apparent distaste for my jokingly applied post.
Old 10-24-2008, 11:50 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: Engine Swap
If that's the case, I have a 1989 Honda Civic DX Sedan, 1.5 liter, port and polish, 3 angle valve grind, header, intake, full exhaust, lightened 240 lbs. I want to swap it with the J32 from a Honda Accord. I have nothing for this swap.
you do know that every thread you post in a thread you jacking it and making it about you
to the OP...what's your question?
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-24-2008, 01:20 PM
Re: Engine Swap
And i also have the engine to complete the swap and just dont know how the wiring is going to work can someone help?
Old 10-24-2008, 05:15 PM
Tony's Avatar
TLD Member #1
Re: Engine Swap
Ok, so the question is: What wiring do I need to do to install a D16Z6 in my car with a conversion harness?
Now my question is: What kind of conversion harness did you get that didn't come with instructions?
I ordered a Boomslang OBD0-OBD1 MPFI conversion harness for one of my hatches. It came with instructions, which are also easy to find online, and tells you exactly what all needs to be done. Ofcourse, the way I am, I modified it a little more than they did and I don't have to run as many wires back to the ECU harness as their instructions call for.
Tony
Old 10-24-2008, 06:30 PM
Re: Engine Swap
Obviously, you didn't note the sarcasm in that post... nor did you notice the agreement w/ Tony that there was never a question asked. Good eye, my friend.
OP - The instructions for most harnesses from reputable companies are available on their websites. You may also be able to find a copy of then by using Google.
Old 10-24-2008, 08:12 PM
BLU CIVIC's Avatar
調整器
Re: Engine Swap
i type the truth
The name's Adrian
2011 CR-Z - Stock
Old 10-25-2008, 01:34 PM
D16Z6 swap dpfi to mpfi conversion
My question is how do i complete the swap. I already have the conversion kit obdo to obd 1, d16z6 engine and also the vtec computer. I will also need to convert from dpfi to mpfi. What steps do i take, and where do i begin. Please reply.
Old 10-25-2008, 02:28 PM
FrodoGT's Avatar
Re: D16Z6 swap dpfi to mpfi conversion
http://www.angelfire.com/d20/hcivic88/4gtech.html
http://www.geocities.com/teampimports/fuelinj.html
http://www.geocities.com/c_rexboy/mpfi.html
The first one contains specific info on the z6 swap.
Current project:
Rio Red 91 hatch.
Old 10-25-2008, 02:32 PM
FrodoGT's Avatar
Since you have a conversion harness you really only need to do link 2 and 3, which are the same thing, the mpfi swap. You will need to redo your distributor wiring as well. The first link just has tips on getting the engine into the car, like which mounts to use etc.
Current project:
Rio Red 91 hatch.
Old 10-25-2008, 02:53 PM
Tony's Avatar
TLD Member #1
Ok, I was taking up for you before, but now you go and create another thread asking the same question you finally asked in your other thread?
EDIT: Ok, look, it merged right into the old thread flawlessly. Don't create new threads asking the same question. If you want help, you will have to help us help you when we ask a simple question.
You still didn't answer my question: What harness did you get and why do you not have instructions with it?
If you want a DPFI to MPFI How-to, I just recently did a How-to on it, with pictures, showing a few different ways to go about doing the swap. Check the FAQ...which I also just recently went through and made it easier for noobs to look through.
Tony
