Old 10-23-2008, 11:39 AM
beachrog beachrog is offline
Coolant Leak
I have a 1997 K1500 4WD and it is leaking coolant. Earlier this year I replaced the radiator and I've checked all the lines going into the radiator and they seem alright. The coolant seems to accumulate on the inside of the front bumper on the passenger's side.
I originally thought it was from a return stub on the new radiator that my truck doesn't use as the cheap cap they provide seems to leak a drop every now and then. But this other leak is more.
It's probably leaking somewhere towards the center and then rides down the rail and drops to the bumper. I'm looking for suggestions as to where to look as I can't seem to locate the leak.
Thanks in advance for your thoughts....
Old 10-23-2008, 03:21 PM
2000CAYukon 2000CAYukon is offline
Re: Coolant Leak
The system should be pressure tested to pin point the leak. It could be the intake manifold gaskets leaking. I have seen it leak from the block onto the frame rail.
//2000CAYukon
Old 10-23-2008, 10:44 PM
j cAT j cAT is offline
Re: Coolant Leak
If it is leaking on the front bumper it must be coming from the radiator... remove the covers and look for the leak , if necssary remove radiator to get a better inspection... and if necessary I would put 5-10psi of air in the radiator when removed and look for bubbles ...intake manifold is usually down the back of engine unless you park facing down a steep hill.
your hoses are easy to inspect so that should already have been ruled out.
Old 10-24-2008, 06:55 AM
Re: Coolant Leak
Thanks to you both for the replies, this gives me something to go on. I'll be so ticked if it's the radiator. I just replaced it no more than 6 months ago. Although I did get it from NAPA....
I've also noticed that if I fill the system, including the reservoir tank, over time the reservoir will empty out, but the radiator always stays full. This made me think it had something to do with the reservoir tank or the hose(s) running to that tank, but they are so far back it shouldn't hit the front bumper.
Sometimes when I shut the engine off and I'm sitting in the truck, I here a sound from under the hood like a "glub, glub, glub....glub, glub, glub....glub, glub, glub....etc." Is that coolant moving to and from the reservoir?
Old 10-24-2008, 09:39 AM
Re: Coolant Leak
Sometimes when I shut the engine off and I'm sitting in the truck, I here a sound from under the hood like a "glub, glub, glub....glub, glub, glub....glub, glub, glub....etc." Is that coolant moving to and from the reservoir?[/quote]
ya thats what you will hear when the air is being transferred within the coolant system as when engine is shut down the coolant temp rises for a time...
lets say the radiator has a defect...NAPA should take it back with your receipt...before installing the replacement do I as I said pressure check first then install....
Old 10-24-2008, 01:17 PM
Beaner81 Beaner81 is offline
Re: Coolant Leak
Just for kicks take a look at the wheap holes in your water pump, if you have any white tracking marks you need a new pump. Remember there is one on the top and bottom so check both.
Old 10-30-2008, 11:50 AM
Re: Coolant Leak
This thing has me soooo puzzled, I checked the weep holes on the water pump, nothing there.
This is the latest that I've noticed, I refilled the reservoir and the leak down the passenger side of the frunt bumper got worse until the reservoir was empty again. The radiator never gets low even though it's obviously not leaking straight out of the reservoir tank and the leak is evident towards the front. It gets so bad after refilling the reservoir that it actually pools in the fan shroud. I put a pressure tester on it and could not locate the leak.
So my questions are:
1) Since it leaks more when I refill the reservoir, does that mean it's only leaking when it has a certain amount of pressure (I'm assuming if the system is truly full the way it should be then there's more pressure??)
2) Since it's bad enough to pool in the shroud but I can't see anything when I put a pressure tester on it does that lead to anything?
I suppose the radiator could be defective and leaking somehow and I just haven't been able to see it, but then why does the coolant level in the radiator itself never get low?
Old 10-30-2008, 01:47 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Coolant Leak
If it isn't leaking when doing the pressure test, then I'd guess that it is leaking somewhere between the reservoir and the radiator. Check the hose for loose fitting at the radiator or cracks. Also check the nipple itself for excessive flash from the molding process where the parting line would be...take a knife & smooth this out.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-30-2008, 05:38 PM
Re: Coolant Leak
the coolant system pressure is determined by the coolant cap....your cap if old should be replaced...the coolant res. should be removed and cleaned the tested with air pressure and look for leaks...then check and replace any hoses that are cracked or excessively soft...
when you reinstall wash all coolant spills and fill res to the full cold level.....idle it and block radiator air flow so it will get hot ...look for leak...
Old 10-31-2008, 07:06 AM
Re: Coolant Leak
Ok, I think I've got it figured out. Are you guys ready......
loose cap
there I said it, I'm embarrased but I admitted it.
When I replaced the radiator I knew enough to also replace the cap, but it doesn't seem to fit quite right. If I push down on it hard enough, I can keep it spinning as I turn it, it never "locks in". Yesterday, I was messing with it and putting slight pressure on it as I turned it and.....click.
I didn't think you should be able to spin those things like that. I'm wondering if I should get a different cap. This one seems to be fine now that I've got it positioned right, but it doesn't seem like you should need to finnagle a cap to get it in the right spot.
Old 10-31-2008, 10:10 AM
Re: Coolant Leak
loose cap
thanks for that info...the cap on a radiator is a bit difficult with the pushing down pressure....before rotation...the other inportant item is to get a cap with the same or slightly less pressure...never put a 16cap on a 15 psi system...
that why I stated to replace the cap when you stated the res level droping only... good luck..
Old 11-19-2008, 09:46 AM
Re: Coolant Leak
I have officially learned my lesson:
NAPA sucks!!!
So I've been chasing this coolant leak for awhile. In the meantime, my wife's Pontiac Montana needed a fuel pump. Got one from NAPA, installed it, worked for a day, went back to NAPA, got another one, installed it, working ok so far, but I'm less than confident.
My coolant leak was getting worse. I removed the skid plate to see if that would help me track it down. I can replace stuff, but diagnosis is a challenge for me. So I can see coolant all over, but can't tell where it's coming from. Not getting good heat and it's cold, so I finally give up and take it into the dealer.
They call me back, said it's got two leaks. One is the intake gasket, leaking pretty good. I actually knew about this one, but was hoping to last the winter and tinker with it when it got warm. But, now that I am thoroughly defeated, I accept their offer to fix the intake for $570.00.
Second leak is ------THE RADIATOR------, so bad $300.00 fuel pump, bad $300.00 radiator. I will never, ever, in a million years buy another thing from NAPA. Call NAPA, state, I just did this radiator in May of this year. Response - that's too bad. Dealer says they can do it for parts and labor for $369.00.
Now my total bill is up to $960.00 or so with the dealer. But I'm extremely frustrated with NAPA. I believe the exact price I paid for the radiator from them was $270.00. And the dealer can put in a GM radiator with labor for $370.00????? Why the hell did I bother trying to do this one myself? I mean $100.00 is $100.00 but not when you get crap parts.
At any rate, I learned alot through this process. I was so proud of myself for doing the radiator without the help of my step father who is a mechanic. Just to find out it's leaking again.
Alas, I'll have the intake done, radiator that will be warranted and hopefully good heat in the truck.
NAPA is the and to them I say !!!
Old 11-20-2008, 10:31 AM
Re: Coolant Leak
this is something that can happen when you put off your maintenance....working in the cold with no garage is very nasty...
you have a vehicle that is old...when you own vehicles such as this you must have/develop repair skills...the cost of having others repair/routine maintenace of this vehicle would be very costly...If you find that performing these tasks is overwhelming , you should buy a newer vehicle that will in most cases require less severe repair demands...
hopefully the dealer will give you a guarantee on this work performed ...because if you have problems,,,, napa and this dealership will be lessons learned as a vehicle owner..
NAPA has some parts with warrantee...before buying/call and find out the policy on returns....lifetime warrantee or at least 1 year is needed...if the warr is 3mo. you know its junk...
last posting I thought you had this under control...
Old 11-25-2008, 07:06 AM
Re: Coolant Leak
I appreciate the thoughts J-Cat. I used to lease myself a Cadillac and my wife an Equinox and realized the money I was throwing away. I actually enjoy working on vehicles but obviously my skill set is still limited. I knew when I dumped the leases and got the vehicles we have, the responsibility of maintenance would be on me.
I still have feelings of nervousness and self-doubt before I start what I feel are big projects like my wife's fuel pump and my radiator. When you're developing those skills, it is important to have confidence. I'm also trying to limit the amount of imposition on my step-father for help.
So when I gather the courage to get one of these jobs done and I end up doing the repairs correctly but end up with junk parts. It gets frustrating and you begin to question. I just need to remember it wasn't my fault.
I was looking forward to tackling the intake gasket, but gave up. So it's done and the truck runs great but I am disappointed.
Old 01-21-2009, 10:39 PM
Jessica2008 Jessica2008 is offline
Re: Coolant Leak
*spam removed*
*SPAM REMOVED*
