Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 10-23-2008, 09:45 AM
jm110105 jm110105 is offline
Keyless Entry Issue 98 Mountaineer
I just bought a 98 mountaineer and they didn't have the code to give me... Is there a way to reset the lock code and program a new one? Also I only got one key for the truck and the key only starts the vehicle but does not let me open the doors... Is there something I can do with the silly code so I can get in the truck if my remote battery dies?
Old 10-23-2008, 09:29 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Keyless Entry Issue 98 Mountaineer
They've addressed this a few times over on the Explorer forum. I think you'll find your answer here.
-Rod
Old 10-25-2008, 12:41 AM
mountainman1 mountainman1 is offline
i have a 98 mountaineer...my key will open the passenger door, but not the drivers door..i have to pull the lock...seems the winters here have made it so the cylinders don't turn in the lock(salt i assume...)...easy fix....
WHEN YOU SEE THIS U C THE BEST
Old 07-31-2009, 09:32 PM
jamesbkimbler jamesbkimbler is offline
I have a 97, and had the same problem. I found the code on the power lock control unit which (in my 97) is located behind a panel in the rear drivers side of cargo area. I had to use a telescoping mirror and a flash light, and found it easily; my code is five digits long.
