New Sound system=new problems.
I have an 03 silverado that i have recently upgraded my subs and amp in, since doing so i get major light dimming and voltage drop from battery meter. The amp is a kenwood Kac-x20 and 2 rockford p3shallows which are bridged to 4 ohms at 520rms, in a sealed box, the wiring is 8guage with an 80 amp fuse. I have the stock alternator and a newer delco battery. I have heard suggestions of
Better Battery, Larger wire, Cap, replacing the ground wires on alternator,battery and engine. I do not feel that i need to do all of those as I used to have 1800watts rms in an s-10 and never had an issue. Any suggestions would help. Thanks in advance |
Re: New Sound system=new problems.
If your lights are dimming; your system is pulling more load than your alternator can supply.
You have 2 options.. 1. upgrade alternator (What do you have now?) 2. install a capacitor to 'cover' the drain your amp is using when it hits. Caps are amazingly powerful.. so handle with care if you go this route. When you refer to your S 10; what was the output of it's alternator? |
I have only used stock alternators in any vehicle i have had, the s-10 was the 2.2 4 cyl and the silverado is a 4.8 delco alternator
Installing a large UFD capacitor in the correct place with a much larger alternator should help and eliminate your problem.. try to find a 140 amp that will fit properly, and this may mean belt pulley changes..as well .. It is possible that you may get by with just the cap...but in any case you will cook that alternator...it will get very hot.... |
Forget a cap, new battery or new alternator until you've checked and/or upgraded your wiring. Most dimming problems can be solved by upgrading the "big 3" wires. IMO there's no reason you should get significant dimming with that amount of power. I'm running two amps totaling ~800w RMS and the only time I get any noticeable dimming is at idle with the system cranked and other electrical accessories running.
then why have a 1000w amp that draws 60amps...should get a 100w amp and then you don't have these issues.. |
Today i picked up a 140amp alternator, do i absolutely have to replace the wires to and from (the big 3) or will i be ok to run this way till I see some warmer weather, Sick now from doing a coolant system flush on blazer. The alternator on there now is 105 amp, and according to what i have read so far the alternator 140amp is a stock option on the truck
