Old 10-22-2008, 04:24 PM
Slated4Greatness Slated4Greatness is offline
Water pump pipe
We were working on our 1993 Cavalier RS 3.1 and a hole developed in the metal pipe that runs from the waterpump around the side of the engine, T's off to the intake and then dissapears behind the engine toward the firewall. Is this common and is it a total PITA to replace?
Old 10-22-2008, 08:45 PM
Schrade Schrade is offline
Re: Water pump pipe
You might be able to get away with a piece of hose repair.
Cut the section out with a cutting tool / wheel. Smooth off the cut edges. Put a length of hose in place of it, and clamp it with band-type clamps - as wide as possible for the size.
Old 10-23-2008, 01:54 PM
muff34 muff34 is offline
Re: Water pump pipe
my`91 with the 3.1 did the same ,I just replaced line with heater hose
Life Is A Highway ,Enjoy The Ride
Old 11-04-2008, 03:01 PM
Re: Water pump pipe
Thank you. I will take care of it this weekend.
I also had trouble with the little brass 90° fitting on top of the thermostat housing. I tightened it too much and broke it off... Doh!!! I can't find the stupid fitting 1/8 90° to 5/16 or something close to that. The larger end appears to have what I would call a inverted flare fitting.. I ended up with a 1/8" 90° to barbed fitting. I'll end up cutting the end off of the metal line and using a piece of rubber house between the two like was recommended for the other metal line unless someone knows where I can get the correct brass fitting.
