Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-22-2008, 01:59 PM
BOX88 BOX88 is offline
New wheels.. New bolt pattern?
I wanted to get some new wheels something black and was thinking about some cragars not sure which size yet cause im going to go with a disc brake conversion and bigger brakes
Now I believe the bolt pattern on my 87 is 5 x 4.75 in. But I was planing on getting a rear axle from an impala for the 8.5 10bolt. But the pattern for those rears are 5x5 correct? Is it possible to actually change my front bolt pattern to a 5x5 too, to match the rear besides wheel adapters, I will not use those at all. I dont think I have ever heard of anyone actually changing their bolt pattern though so I had to ask.
Old 10-22-2008, 04:22 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: New wheels.. New bolt pattern?
I haven't done it personally, but you can get the left and right front hub assemblies from any B-body GM car that has the 5 x 5 bolt pattern. All older GM station wagons came this way so if you find one of them in a bone yard your set. Be sure to replace the wheel bearings and brake assemblies as sitting in a yard isn't exactly the best thing for them.
Old 10-22-2008, 05:45 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
You can get the rotors/hubs/steering knuckles from the same car you get the rear axle from. This is what I would suggest as the whale body cars have metric studs (12mm) while the boxies have SAE studs (1/2"). Keep the car the same.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-22-2008, 05:47 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
I think you mean spindle assemblies and rotors, which include the hub.
My wagon has the 5x5 pattern and has 12" rotors.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-22-2008, 08:18 PM
Thanks, I was hoping to hear something like that. Having two different bolt patterns would suck.
Old 10-23-2008, 04:12 PM
PeteA216's Avatar
Thats exactly what I meant, but couldn't think of the word at the time.
