Old 10-22-2008, 12:26 PM
Judaspixie Judaspixie is offline
Help! Front vents won't work
I have a 93 lumina. Now, among the many issues I've had, this has been the most puzzling. My blower fan went up. It was replaced a little while after and now my front vents won't work. The defrost and floor do! Does anyone have an idea where to go from here?
Old 10-22-2008, 12:36 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Help! Front vents won't work
Most common problem is loss of vacuum supply to vent actuators- due to a vacuum leak underhood- On "W" cars such as yours- look for the black plastic vacuum line to be corroded, broken in two, cracked etc- right by the battery- as it goes down to the vacuum reservoir in front of driver's side front wheel. For safety reasons, the air comes out the defrost in case of loss of vacuum supply- Plastic supply line can be fixed by splicing a small rubber hose over both ends after trimming the plastic-- the battery gases work hard on those lines--- I have also seen the battery sitting directly on top of that line on a "W" car.. Hope this helps....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 10-23-2008, 01:45 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
If this has happened only since the blower motor was replaced, then it is probably a pinched or loose vacuum line in front of the dash.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
