Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 10-22-2008, 12:18 PM
Scott1234 Scott1234 is offline
Front end noise
My 1999 Avalon is making a noise at low speeds. At very slow speed it seem to coincide with the rotation of the front right tire, but sometime during a turn I can hear a rattling sound sounds in the area of the wheel well. I had a mechanic check my front end and he said all was good. I hit a large pothole a couple of months ago, and the noise has started sometime after that.
Any ideas would be appreciated.
Thanks
Scott
Old 10-27-2008, 11:28 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Front end noise
Could simply be a loose or broken wheel cover (unless you have alloy wheels).
Other more serious possibilities could be a damaged CV joint or wheel bearings, which aren't visible in a quickie inspection.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-27-2008, 11:50 AM
Re: Front end noise
I do have the alloy wheels. The noise comes and goes. I guess I need to have the wheel bearings checked. I pulled the tire off the side the noise comes from and the CV looked OK (at least no leaks or tears in the boot) It almost sounds like the strut is loose, but I could not feel any play. Are their any cushions or mounts that may need replacing?
Thanks
Scott
Old 10-30-2008, 12:17 PM
jdmccright's Avatar
The RustBuster
Re: Front end noise
There are spring isolators (rubber pieces between the spring ends and the spring seats on the struts), but the rattling could also be the strut mount. Relieving the spring tension with a spring compression tool is needed to check this out.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 10-31-2008, 10:57 AM
Re: Front end noise
I want to thank you for your help. It is almost too embarrising to admit that it was simply loose lug nuts. Evidently when I pulled the front tire to check the break wear I forgot to tighten them. I have corrected that situation and no noise since then.
Thanks
Scott
