Old 10-22-2008, 11:59 AM
toyo94 toyo94 is offline
lost power
i was replacing the stereo on my 94 Toyota Tercel and the new unit worked for a while then sound changed and finally i lost power to the head unit along with the clock. there were couple of unhooked wires at that time and i am guessing some kind of short circut. radio/clock fuse inside the dashboard looks fine. i plugged in the old stereo and still no power. any suggestion where the porblem could be.
Old 10-22-2008, 05:00 PM
PlayStation3 PlayStation3 is offline
Re: lost power
did u check the fuse on the headunit itself?
Old 10-22-2008, 05:11 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: lost power
there are also fuses under the hood
Old 10-22-2008, 05:14 PM
AWP9521 AWP9521 is offline
Re: lost power
Must be another blown fuse down the line, There should be 2 fuses for the power leads for the radio, one the the switched power lead and one for the memory lead. Visual inspections of fuses may not find a blown one, I have pulled fuses that looked good but were actually bad. I would pull the fuses and check with an ohm meter or continuity tester.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 10-23-2008, 04:50 PM
Re: lost power
thanks for all the replies. it was a blown out fuse under the hood that looked good but was burnt when i took that out. thanks again to all who have replied.
