Old 10-22-2008, 12:47 AM
tcoltrain tcoltrain is offline
Question Cooling Fan Runs Constantly
2003 s-10 4.3l v-6. The cooling fan runs constantly except when engine is off. When the engine is off i can manually turn the fan it is firm not extra loose or grinding. Help!!!!!
Old 10-22-2008, 08:53 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Cooling Fan Runs Constantly
Manual clutch or electric fengine cooling fan?
MT
Old 10-22-2008, 09:39 AM
Question Re: Cooling Fan Runs Constantly
electric engine cooling fan.
Thanks ahead of time for any help.
Old 10-22-2008, 09:42 AM
Candygirl82 Candygirl82 is offline
Maybe it's an electrical fault somewhere, you should have it checked out, just now the motor burns out.
Check Out What Land Rover Have Been Up To!
Old 10-22-2008, 11:27 AM
MT-2500's Avatar
AF - Advisor
Factory setup or add on?
MT
Old 10-22-2008, 12:50 PM
Schrade Schrade is offline
Any 'check engine' indicator?
Old 10-22-2008, 03:39 PM
Factory set-up
Old 10-22-2008, 03:40 PM
no check engine light
Old 10-22-2008, 04:58 PM
MT-2500's Avatar
AF - Advisor
Factory set-up
Rad fan?
Check relay and sensors that control the fan.
A good engine capable scanner would help you out on it.
Good Luck
MT
Old 10-22-2008, 05:54 PM
Rad fan?
Good Luck
It is the rad fan. where should I go to find the scanner?
Old 10-22-2008, 06:01 PM
MT-2500's Avatar
AF - Advisor
Dealer or Most good repair shop have them.
Should have a stored code.
Post back code no.
But to be on safe side switch the fan relay with a known good one first.
And run your vin no for recalls and TSB on the problem.
Good Luck
MT
Old 10-22-2008, 06:16 PM
Scrapper Scrapper is offline
AF Premium User
i'll bet it's your relay like he sais check that first.
Old 10-22-2008, 06:51 PM
Thank you everyone for your help. I will repost the code if I get one. And I will check the relay.
Old 05-16-2009, 08:32 PM
SuperTen's Avatar
SuperTen SuperTen is offline
Deffinately check the wiring... Cause its possible that the wiring has melted together somewhere.. Only if you wire it straight to the battery will it not shut off.
